I am far from a Luddite when it come to things electro mechanical but this has got me going around in circles;
so this is one for those of you that are upto speed on 12v hab electrics including solar.
i have an exide 80 ah Gel hab battery connected via schaudt electrobloc unit to the hab electrics and this has a schaudt 1218 solar controller( 140 watt ) which charges both Cab and Hab batteries when on solar or EHU. the Schaudt control panel display shows solar charge either to Hab or Cab as selected.
Ok... evrything seems to work as it should, use up some juice and you can watch the solar display both hab and cab charging current from the panel. both batteries are getting fully charged.
However, even when everything is fully charged ( and even if the EHU is connected i have a constant 0.2 / 0.3 amp charge from the solar panel to the hab battery, even with the hab electrics switched off at the control panel.
to me that seems to indicate that the hab battery has a parasitic drain. which i have tried to find.
in all of this the cab battery behaves as i would expect, gets its charge and then reduces until it takes nil from the EHU or solar,
i have puled every fuse! checked all hab circuits and still it shows a fluctuating 0.2 / 0.3 amp charge going to hab battery no matter what i do. if i switch stuff on then the charge from the panel changes as you would expect with the additional load.
any "Helpful"
! ideas???
I am now really banging my head!!
any "Helpful"
