Habitation Door Latch Return Spring Failure (1 Viewer)
Jul 1, 2010
3,146
26,398
SW Northumberland
Hymer B 588 DL
Since September 2010
Newer Hymer model with the Comfort pack and wider habitation door, return spring on upper latch failed recently so latch had to be pushed back whenever door used or it fouled door frame. (The standard door has only a single latch) The entire latch was replaced under warranty dealer mentioned they had a couple of customers with same spring failure. So I would like to source a couple of spare springs just in case as our warranty expires this month. Has anyone been this route and obtained any? If so please post.
Photos show latch mechanism minus the spring, not sure if both latches are the same, Manufacturer is Fap Firenze (Italian I think) serial number is shown in photos if anyone could point me in the right direction for spares I would be most grateful.
Oct 20, 2010
2,202
37,419
Burry Port South Wales
Since 2003
I have never found a supplier of the springs and now make my own. The top and bottom springs are 'handed' an as such are different.
We would be very interested if a supplier is found.
Ed
Steve and Denise
5,049
13,083
Spalding LINCS
A Class Carthago
Since 2008
We had one fail on our Rapido same type as Eddies but looking at the Hymer door that may be a bit more involved in getting the cover of the door it’s a very tight fit.
Oct 20, 2010
2,202
37,419
Since 2003
The left and center are the sheared springs, the right is a replacement I made which was my best effort after a lot of faffing about.
Ed
ctc
Oct 12, 2015
1,429
2,351
Crowle
Hymer b680
New
Did anyone get anywhere with sourcing these springs? Both mine have gone and how do you remove the inner part of the door?
Oct 7, 2013
5,750
35,975
South Wales
Swift Escape Compact
Since 1988
Have you tried a local locksmith?
They usually carry a supply of various springs. One may be suitable.
