Grey water tank not emptying (1 Viewer)
Oct 9, 2019
4,959
17,300
Todmorden
Van conversion
FUNSTER in a PVC
We are very careful not to let food stuffs go down the plug holes but during this first trip in ages, the release tap just trickled and now nothing is coming out of the tank. It is CAK tank 70ltrs and is now showing half full. Previously the tank would full flow empty at a quarter full, now nothing.
What methods can I use to clear the tank ? sensible ones please šŸ˜†
TerryL
6,187
8,190
North East
Low Profile
Piece of curtain wire - or even a plumbers wire - pushed GENTLY up the opened outlet. Be prepared with a suitable receptacle...............
Odds on a small weee beastie made it's home up there and died!
May 17, 2016
3,610
7,833
Aberdeenshire
B524
2nd base
What diameter is the outlet? The narrower ones are quite easily clogged no matter how careful you are with waste going down the drain.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
It's normally a wasp's nest or suchlike. Poke it out with a bit of wire.
Feb 25, 2020
247
490
PPVC Autocruise Alto
I'm a newbie
When I replaced the rusted hanging straps on my Autocruise Alto it was an ideal time for a good swill around so Consider checking hanging straps if they need replacing disconnect electrics and pipes and remove etc
Jun 25, 2016
182
338
Ynys MĆ“n, UK
2016 Benimar 243
Since 2016
It has been known for some Motorhome s to come from the factory with the disc cutout to be left inside the tank when they cut the hole for the outlet, which then moves about randomly blocking the outlet.
Oct 22, 2020
22
40
Since 1998
Some twenty years ago I had a very unpleasant experience with a two year old van I had purchased. I removed the grey (red) tank bung and what it contained was somewhat unpleasant. So three vans later I never carry water in the grey tanks ( I have two) Being an ex Scout where we were told to Bucket and Chuck it thats exactly what I do. Maintenance wise I reverse fill the tanks and use Biologigal washing powder to clean the, annually.
Dec 31, 2016
248
160
southampton
Hobby Toskana 750
Since 2019
ive had this problem because the ground was very unlevel, so the water didnt drain out. Tried in a different waste station and it worked
