Grey Water Drain Tap - temporary fix advice please (1 Viewer)
Daveg
151
165
Perthshire
Low Profile
November 2012
I am going to order a new one for our LMC, but need a temporary fix. There is a 40mm external diameter rigid plastic pipe (35mm internal diameter as near as I can measure it) onto or into which I need to push a tap.
Can anyone advise on a simple and effective solution please?
Dave
Jul 5, 2013
11,735
13,722
I am nor sure that would be watertight enough. The socket on my Hymer does not have a sealing ring, so OK to empty using some 40mm pipe but no good for holding back any head of water. After all the OP does not want to be a grey dribbler. (y)
R
Robert Clark
How about a 40mm solvent weld valve as used on swimming pool pipes
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
Have you managed a repair?
If not, could you fit a gate valve onto the pipe?
