- Apr 6, 2019
- 5,425
- 10,997
- RV
- FourWinds Windsport 6.8L V10
I wouldn't normally promote flEbay but this looks great?
Plenty do - but you're right you do need to bear it in mind when choosing one.Only if you have a controller able to handle that voltage....![]()
Construction is no different to any other rigid panel.Looking for another panel , but are these made for houses , would they stand up to slight flexing, just asking maybe someone will know
Should think these will be ok on a motorhome. I've had two on mine for 5 years and they are still going strong.Looking for another panel , but are these made for houses , would they stand up to slight flexing, just asking maybe someone will know
With the solar electric roof thing being done away with I wondered if you fitted your own and run it to an emersion heater in the hot water tank at home would it still be viable thing to do.
Another alternative, especially if you don't have a hot water tank but have a 'combi boiler' that heats the water on demand. A 'heat battery' uses solar electricity to heat a solid/liquid that melts at about 80 degrees C. It is very well insulated, so it loses heat very slowly - a small fraction over 24 hours.There are devices that sense when not all power is being used by the home they're attached to that will turn on an immersion or other appliance.
Could you not fit some extra panels just for your own use and leave the existing ones feeding into the FIT?Last year I re-arranged the way we heat water to use the solar panels to heat the water during the middle of the day i.e. when they produced maximum power. Seemed to be reasonably economical, although they were of course "topped up" by the normal electricity supply.
However last week I decided to experiment and went back to heating the water by gas - on all the time as we've got an ancient system that won't take a timer (although we're currently looking to change that). As we have an energy monitor it was quite easy to judge the effects and we found it was actually cheaper to run the water heating on gas.
Now to your question. Our panels (6) put out 1.4Kw maximum, as recorded the last few days and over about 2 hours mid-day. Our immersion heater is a 3Kw model so I would guess powering purely by solar panels would work, though not very well, but you would need to install at least 10 panels and frankly the cost just wouldn't be worth it. You'd never get your investment back.
As an aside, we were fortunate to get the panels installed before the Government reduced the Feed-In-Tariff and we've benefited ever since - our annual energy bill is less than £300 - so I've calculated we'll get our money back in 10-12 years. Only wish we'd gone for more panels but our advisor didn't think the extra cost was worthwhile at that time - can't just add panels now or we'd lose the FIT.
Well I suppose it's possible but as the whole system is set up to feed into the electricity supply it would take a bit of trickery to keep additional panels separate and still get some benefit. It would also probably negate the terms and conditions that I have to confirm every time I claim FIT. Not worth it IMO but thanks for the thought.Could you not fit some extra panels just for your own use and leave the existing ones feeding into the FIT?
