Hello,
I've just joined the forum ... my mid-80s parents are having an electrical problem with their Globecar Ford Transit camper van. I'm trying to help them sort out an electrical problem with the habitat side of their camper van and I've already done a search on the forum and can't find anything to help me.
It is quite an old Globecar ... originally manufactured in 2007.
The basic problem is that whilst the electrical side of the van/engine is fine, there doesn't appear to be any power getting to the leisure side of the campervan, e.g. lights, electric toilet flush, etc.
It has a LT 410 control panel and whilst if you push the correct button it shows the charge of both the van and habitat batteries, if you push the rocker switch to enable battery power to the habitat side the LED above the switch does not come on.
I've looked everywhere for loose wires or blown fuses, but can't find anything obvious.
It has an Electroblock EBL 99. The master switch on the EBL is on and I can't find another electrical master switch. There doesn't appear to be an 'on' light on the EBL and I was sort of expecting the click of a relay when you switch it on, but there is nothing.
I'd contacted Apuljack and a helpful person suggested that there is a known problem with a 2A fuse in line with the leisure battery. Apparently there is a 'sense' feed to confirm a battery is connected and apparently this is a common culprit for this type of problem.
Under the front passenger seat there is just the EBL 99, and under the driver's seat there are two batteries. Both say they are Ford batteries which in conjunction with the date on the battery (2007) suggests to me these are the original batteries from when it was manufactured. I know that in itself may well be a problem as we are looking at batteries that 15 years old and probably well past their expected life. The two batteries look like they are connected in parallel, so I suspect these two batteries are for engine, etc and not one for engine and one for leisure. Can anyone comment on that?
If this is the case I'm wondering if there is another leisure battery (complete with sense circuit and 2A fuse) hidden somewhere else in the vehicle. Can anyone cast any light on whether we should be looking for a separate leisure battery somewhere else in the vehicle?
We have phoned around trying to find somewhere who can take a look and repair it, but we can't get it booked in until September. So we continue to try and locate the problem.
Any help or suggestions would be greatly appreciated
Regards,
John.
Regards,
John.
