Gaslow big ask for help
England, UK
Learning all the time
We fulltime and are stuck on a site. Owner has put barrier up to stop people getting on. Its stopping us getting off as well.
So here's the thing we cant get off to fill our gaslow system. Tried ringing gaslow but there closed for the duration. So cant buy the adapter and parts we need so we can use a propane bottle.
So am asking does any one here have one that they would sell/loan me.
I would either buy it from you. Or buy a replacement and have it sent to you as soon as gaslow open again.
Been on amazon and ebay cant see one. And dont know what parts I need to by pass system.
Hope some one can help.
If you have a bbq point fit a normal bottle to that, you would need a regulator on the bottle.
On my setup I have a standard regulator on each bottle So I can just remove that and fit to an external bottle if needed
Where in Rutland. Just check an post office is still working. We would cover all costs of P&P
Are you looking for a propane pigtail to use in your gas compartment with the propane cylinder, or do you want to run the gas through the gaslow filler point?
Ed
If you have a calor bottle and pigtail hose you can connect directly to your bulkhead regulator. Removing one of the gaslow connections at the bulkhead regulator
Ed
Would prefer through filler point. As not very technical minded
Gaslow does a pipe that goes onto your fill point for connecting to an external bottle.
Gaslow shut for the duration
This should work
Okay, back to the real issue ... your 'site' cannot hold you 'hostage' ... are they refusing to let you go fill up and return? Its no different to if you needed to get shopping. What are they saying?
Like this:
I'd send but can't get to a post office cos self-isolating. I did try it once (unsuccessfully) with a gaz butane bottle but it was too cold for the gas to vapourise.
If you look at another post of mine there is the stuff we need in a picture a propane bottle plugged into a van.
Cant do link to my post. But title is Gaslow out for season
Am I right - I'm sure our Gaslow tank had a standard "Calor" thread on it. It would fit straight into an off the shelf "Calor". In fact early on I carried a Gaslow and a stand-by Calor bottle. I'm talking quite an old Gaslow.
Ok, I can send you the hose that will fit into the filler point, do you have a propane cylinder adapter for the hose?
Sent you a PM and no to propane conecter
This is the adaptor for the propane, order it they say they can deliver Friday.
Ed
  • Informative
Reactions: f6c
Ed
Order the part.
Thanks again. Let hope it all works
Reactions: f6c
Only just seen this thread Innkeeper
I have an unused Gaslow filler to link propane Calor cylinder to your filler point, complete with the hand wheel adaptor.
I bought it for just such an emergency but never used .. let me know if you still need it.
Reactions: f6c
