gasit position
somerset
firebrand campervan
please can anybody help, can gasit or gaslow cylinders be used horizontally.
No. Bottles and tanks must be used in the specific orientation for which they are designed. It would be extremely dangerous to use a vertical cylinder in a horizontal orientation. There are multiple serious risks. There is the possibility of taking off liquid on the outlet, the pressure relief valve may be defeated, and the 80% refill valve will malfunction.
Definitely not ⚠️
The vast majority of gas cylinders are designed for vapour take off , the only time you will see a specialist type of cylinder on its side is an FLT cylinder designed for liquid take off to run a fork lift engine .
I thought that was the case I just wanted to make sure. thanks for your input
I agree, definitely not. However if you have a space that would fit a horizontal cylinder, you can get a cylinder-sized tank designed for horizontal mounting that will do the job.
Or if you've the funds, and the right configuration chassis, and currently also the patience to wait for a fitting, an under slung tank might work, this also frees up a locker, but at a cost.
Mike.
