gas it refills (1 Viewer)
Jun 3, 2018
217
437
I’ve just fitted a gas it refillable system, I have a few questions.
Can I now just go to any garage and fill it up?
Should the bottle outlets be open or closed?
Is it the norm to spray with a gas leak tester the first time you fill up?
Cheers.
Mark
Lenny HB
50,114
137,928
On the coast in West Sussex
Hymer B678 DL
Yes you can normally fill up at any garage, occasionally you get refused (more lightly if you don't have an external filler), if you do just go to the next one.
Best to close the valves as slight possibility of damaging the regulator with them open. OK open in theory as fill pressure is way below the max the regulator can handle.
Yes important to check for leaks after install, I use a Honywell gas sniffer about £30 always carry it in the van.
mark49
Jun 3, 2018
217
437
Thanks for that info. I’ll close them and fill then.
Where would I get a sniffer or something similar. Wicked, b&q etc or plumbing specialist.
Mar 23, 2012
9,096
29,681
sleights
c class
I would just put a quids worth in first then leak check if ok fill up. I just used the spray to check it.
WynandJean
6,666
3,306
West Midlands
Bailey Autograph 682
Since 2010
Use the apps 'MyLPG' or 'FILL LPG' to locate suppliers. Note that you will pay less at gas companies than garages as garages sell it as an automotive fuel which carries a higher rate of VAT than gas suppliers who sell it for domestic heating/cooking.
Wyn
mark49
Jun 3, 2018
217
437
Cheers on all points. I’ve put a tenner in and checked, couple of points required tightening after smelling the gas and using spray tester.
Seems fine now, I’ll do a complete fill in a couple o days n test again. I’ll be investing ina sniffer for peace of mind.
Thanks again.
