Gas heating stopped working (2 Viewers)
Nov 12, 2016
6
Yeovil
Van conversion
Gas heating stopped working in auto cruise alto. Checked fridge and although I could see the pilot light , fridge was not cold . Gas hob worked but when I tried to use the grill at the same time it was spluttering. New gas bottle , all connected correctly, am I doing something wrong? Any suggestions appreciated. J
Riverbankannie
10,607
62,034
Bristol
IH 630 RL PVC
When you say new gas bottle, how new and how big? It’s obviously shortage of gas pressure so going to be nearly empty bottle or a blockage maybe in regulator,
J
Nov 12, 2016
6
Yeovil
Van conversion
Thank you both , changed gas bottle yesterday, so it’s probably the regulator, will find someone to check it for me
2,412
10,534
JAT...
Are you using Butane (blue bottle) or Propane (Red bottle) ? or are you on Autogas (refillable)
as the ambient temperature drops blow 10c Butane gas production drops off significantly until it eventually stops boiling at -2 C
you should be using Red bottle Propane for winter.. or Autogas (Propane).
If you know that and are already using Propane, then sorry for teaching you to suck eggs.. you have a regulator problem .
J
Nov 12, 2016
6
Yeovil
Van conversion
Thanks for all replies, it’s a Truma monocontrol cs , think that’s the problem , so will have to go to dealer
138go
3,276
14,613
Carthago 138
Since 2001
Buy one off the Internet its only a few minutes job to change one. Bit of soapy water round the joint to check for leaks and away you go. Why pay the Dealer prices.
5,436
21,713
Cumbria
Ours failed on holiday in September and as we were driving through Thirsk, we spotted Autogas 2000. We pulled in, what a lovely couple, couldn't have been more helpful and we bought a replacement (not Truma) for just over £24.
1,856
5,571
Cliftonville
A Class Burstner
Since 2014
Ift is likely the Crash Sensor that has failed on your regulator.
If you get somebody to hold in the green button try your hob and heating, you might find it will work.
If it does, get a cable tie and use something like a small nut and tighten the cable tie around the nut so that it depresses the and holds in the green button. This will keep the gas flowing.
You then have 2 choices.....
1. Leave it as it is just remember to turn off gas when travelling
Or
2. Get a new one fitted.
138go
3,276
14,613
Carthago 138
Since 2001
Lot depends where it is situated and which gas you are using. If you use refillables then their is something extra in the gas that can clog the regulator. Putting the regulator as high as possible helps to stop the goo getting into it. You can also fit a filter but then you have the cost of replacement elements. I bought a spare earlier in the year before we went to Spain just in case we had problems.
Bdeners
60
38
Glasgow
2014 Hobby 65 GE
Since May 2018
Hi Qfour, can you tell me where you purchased your spare from? Thinking about getting one just in case I need it at some point.
1,808
15,411
South East but not London
Rimor Europeo 87
Five years plus three tugging
Is Truma that bad? Or is that it is a very common make, so proportionally more problematic?
If not Truma, which make would you suggest?
Sorry to be a pest, but can I ask again? Are Truma regulators renowned for being duff, and if so, what is a better make to put in?
