Gas filling problem
Fylde coast lancashire
Just been to morrisons and gaslow won't refill,have bottle off at top hose fitted and pressurised got 13p in first attempt 9p on second,any ideas please ?
Most likely the Morrisons tank is empty. Huge demand at the moment.
(I've had the same issue twice before).
driving from crewe to peterboro, we stopped at every (about 7) LPG stops shown on myLPG web page. All empty. Apparently the 'factory' that cracks the gas is being modernised and only producing limited amounts. All Morrisons are empty according to the management and awaiting deliveries. Luckily we found a garage just down the road from the showground and managed to fill up.
Recommend you all fill up when you can.
Morrisons Paisley was fine yesterday 57p per litre
We filled up at Morrisons Boroughbridge yesterday without an issue so there is gas available 'up North' at least.
Can you please translate exactly what you mean by the above?
You are meant to close the valve on the bottle before refilling, and they only got pennies worth of gas,
As spriddler says, probably low or empty station tanks. Similar thing happened to me. Filled up somewhere else successfully.
Filled up at Morrisons Falkirk this morning along with several other Funsters from the Falkirk meet.
