Gas bottles (1 Viewer)
Lookaround
59
19
Ireland
I went to swap my gas bottle at the weekend and found out it is a German bottle and was told they are hard to find - I live in Cork in Ireland. The guy told me I wouldn't have a problem changing it in France as I'm off there next week. Does anyone know if this is the case. I'll put up a couple of photos to show you the type of bottle.
denisejoe
5,621
12,054
Warden isle of sheppy
Don't think you'll be able to swap it in France. You'll need to go to Germany to swap it or buy another bottle.
You might be able to pick up a 2nd hand bottle at the local recycling centre but you still wouldn't be able to swap it in France. You probably need to change the regulator as well.
Denise
2,337
10,145
As said.. you won't find German bottles or be able to swap them in France ..
Better to fit a refillables .. then you can go to any country (apart from Morocco) and always fill up with gas
32,663
66,597
The only bottles which are interchangeable in several European countries are Campingaz ones but they are EXPENSIVE! All others are country specific so unless you are going to Germany you'll need to get another bottle, maybe more depending on how long you are going for and what your gas usage is likely to be, so:
How long are you going for?
Are you going to more than one country?
Will you be using campsites or aires, or if both, then what proportion of each?
What size bottles can your locker take and can it take more than one?
Feb 16, 2013
19,736
52,042
uttoxeter
ambulance conversion
50 years
Now we had threads about this a while ago, where it was said you can get bottles in France that have the same threads or push on regulators as calor bottles , not what you asked but worth a scout round the threads to see what it was about, and get yourself a calor regulator , plenty about. Or your regulator might even work. Won't swap a calor bottle but you could get a French one when you are there.
We have a fixed regulator so it's just a matter of another pipe to fit, we have French ,calor and gasit and can use them all but since we had the gasit just use that.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
The female coupling looks the same as we have here, if that is the case a new, full, bottle 11Kg is only 19 euros at Brico Marche without exchanging an empty one.
Never seen a French bottle that accepts a male end on the pigtale so almost certain an adapter would be needed to swap from a Calor bottle
