FUSES AGAIN
AndyV
France
Coach Built
since 2003
Where is the fuse for the side marker lights on a 590. I have tested all the fuses in the main fuse box below the steering wheel, all ok so there must be another fuse panel in the cab somewhere. Would be very grateful if anyone knows
On our 2006 Ducato there’s a fuse box on both sides.
Thanks Paul, unfortunately on mine 590 2014 it only has one fuse box in the dashboard under the steering wheel
I would expect side markers to be on the same fuse as the main sidelights/rear position lights.
Correct but should be separate n/s and o/s I would think.
Hmmm, ok is there a diagram on the inside of the lid like mine perhaps or in the base vehicle destruction manual?
Yes pappajohn sidelights front & rear do come on but not the markers
Well, they obviously are on the same circuit and if the main sidelights work it has to be a wiring fault.
There will be a common earth, they can't earth through plastic or fibreglass, so I would start there.
Try a meter between a pos bulb contact and chassis......that will confirm if they are getting power.
Then a Neg contact and chassis to check continuity.
Ok pappajohn will try that if I can, if not it's main dealers
Is there not a box under front passenger seat too? I've been without two 12v sockets working for ages and a lovely funster found the fuse there for me. I also have a couple of fuses in the bottom of the wardrobe. (I know different Burstner so sorry if daft answer).
The earth's will most likely be daisy-chained from one to the next and eventually to an earth point.
As they are all not working it will probably be where it attaches to the chassis earth.
