Full? (1 Viewer)
Happy1
516
220
Wales
Rapido A class
12 years
Picked up van Wednesday last week currently in Cornwall trying it out to see how things work or not !
Question, looking at photo of gas gauge on gaslow bottle is it full or empty?
PP Bear
7,806
28,776
Kent, UK
Auto Trail Dakota SE
Full, the gauge will work its way back towards the yellow and then red, with it being empty as the red indicator tails off :)
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
So I thought but cp plus showing error codes on gas (or lack of) but fine on electric
Seems on mine this shows empty not full?!
PP Bear
7,806
28,776
Kent, UK
Could the gauge be stuck.........or it's so empty it's gone way beyond the final red sector and gives a false reading?
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
Empty and or stuck makes sense, thought dealer had filled bottles on install but I guess not
Should have known better as diesel fuel light was on when picked up van so not much chance of full gas tanks
Silver-Fox
9,266
29,098
Cheltenham Spa
Rapido
im a not so newbie
Ive read the gauges arnt the most accurate in the world either.
You could always crack open the fitting to the bottle and open the valve to see if you get gas out of the bottle.
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
Off to the garage in morning to try and fill up with lpg, figure amount I get in will give me more of a clue and hopefully move gauge
MillieMoocher
1,118
10,640
West Yorkshire
Autosleeper Kingham
40 years under canvas: Motorhome 2016 To 2020
Gauge looks like it's showing full.
But I also see that it's a new to you van as you're "trying it out"
May sound a stupid question, but does your control panel allow for "Gas" , "electric" , "mix 1" and "mix 2"?
If you've accidentally selected "mix" and you're not plugged in, you'll get an error message (I speak from experience!)
Have you tried to light the cooker to see if there is any gas coming through?
Also, you'll have some isolator taps for the gas inside the van, ours are located under the sink. If these are in the off position, it could maybe cause an error message (I don't know, cos that one I've not done :) )
But I also agree it's not unknown for the gauges to read wrongly so it is possible the bottle is empty. It might however be worth checking the above before you head off to try to top up.
Good luck!
Shrimp
May 27, 2015
3,986
33,449
Bedfordshire, UK
Hymer B584
Long time
If cooker/job lights on gas fridge should work. Gauge looks as tho Gaslow is full!
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
Thanks for replies, had heating and water running on various combinations of gas and electric no problem until error message and then hob, oven and fridge stopped as well.
Has its advantages Can't cook so off to the pub!
TerryL
6,184
8,186
North East
Low Profile
First thought - you've run out of gas (and thus the gauge is not reading right, not unusual). Try refilling, get the garage to give you a hand if you're not sure.
Second thought - the regulator has packed up, it happens. Plenty of discussions about that on here, search Regulator.
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
Pictures of both gauges after filling two x 11kg bottles to the top!
Literally cooking on gas!!
TerryL
6,184
8,186
North East
Low Profile
Great, problem sorted; as a matter of interest how much did you get in? Remember the fill will (should) cut off at 80% capacity so you can work out how much was actually in them. If I remember correctly an 11kg bottle holds max of 22 litres, but someone can probably correct me on that.
Anyway, those gauges look about right now, however it would be a good idea to experiment to see how accurate they are. Suggest you turn off one bottle and run it out, periodically checking the gauge reading, changing over when it does, then refill and do the same with the other bottle. That will give you an idea of how accurately they show the contents.
The gauges on our two bottles start full but show empty when the bottles are still half full. After a while you get used to how much gas you're using. We just use one bottle until it runs out, change over then think about getting a refill, dependant on where we are.
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
41 and a bit litres when it cut off so think that about right
Having the truma duo cs fitted with remote indicator that shows when bottle changed over so know one left before we run out next time
