My problem is that I seem to have lost the 12v feed to my fridge. I have an Autotrail Imala with a Dometic RMS 8501 fridge. Yesterday the fridge stopped working all lights went off no audible warning, as if it had just been switched off.
I have a 12v neon tester and found no supply to the fridge. I checked the fuse in the Sargent EC155 unit by substitution and found that it was ok.
Further testing showed that there is no output at the fuse on the Sargent unit although all other outputs are ok.
I then disconnected the hook up and ran the engine and tried to run the fridge but still nothing.
I have no access to circuit or wiring diagrams as we are away until Friday.
Does the fridge have a separate supply into the Sargent unit, and if so is it likely that a fuse further back in the supply has blown?
All other functions from the Sargent unit are working and leisure battery is showing as fully charged.
Thanks in advance.
Thanks in advance.
