you need to take of the bottom vent and the wind sheild around the burner to see if the jet lights if it doesnt or is small then you need to remove the jet and clean it if it still doesnt light you need to check there is voltage to both side of the gas valveif theres voltage there and it doesnt light then its gas valve if theres no voltage its probably the pcb
9 times out of 10 it will be the jet
1.5 voltage to gas valve i did have the resistance of the coils(its a two stage valve) but cant find it know but its unliley that both side fail at once so if there's a marked diference between them then one has failed
