Fresh Water Tank valve - what is this called
Not on the Coast East Sussex
Hymer B504
Since 2013
Can anbody tell me the name of the brand or type of valve/plug the black triangle/circle is called please ?
What it is and how to fix it 👍
Its for setting the water level at half full for travelling and to drain the fresh water tank
I don't know what it is called but I had a problem and sorted it as follows: Filled the tank from empty with sterilising solution and let it sit for a few hours. Turned the black triangle circle anticlockwise to empty and... nothing. The turn handle had become disconnected from the valve at the bottom of the tank due to, I think, overfilling the tank and causing it to expand slightly. This lifted the shaft from the handle out of the mechanism at the botttom of the tank, as I discovered when fiddling about inside the tank through the inspection hatch. I partially emptied the freshwater tank by turning on the taps and letting water run through into the grey water tank, which allowed splash free access and a better view. Further fiddling and upward pressure on the shaft allowed it to be lifted over the top of a small cylindrical part and reinserted into the mechanism at the bottom of the tank. Clockwise rotation on the black handle then seem to re-engage the shaft with, I assume, the threaded part at the bottom and the whole thing is now working fine again.
Hope this helps
Thanks for that ;-)
It's broken so I need a replacement and trying to find the name of that particular part.
Hope this helps
Thanks the top is broken so I need a replacement and trying to find the name of that particular part.
