ShiftZZ
Can you power Firestick using DC 12v?
When you say your Firestick struggles on tv usb, how does this show up.ShiftZZ, as advised above Dave, but I find with the 12v TV in the MH, the Firestick 4K operates better from a stand alone USB supply of around 2.1 - 2.4 amps. I don't think the twin USB sockets on the TV are powerful enough.
On the home TV, we power it off the built in USB sockets.
You will need a good WiFi connection, which in the MH, you may struggle with in remote locations.
Good luck with it Dave.
Cheers,
Jock.
It is slow to load up, and respond to signals from the remote, eg, all four iPlayers just kept stopping/starting/freezing, and screen going blank, but as soon as I reverted back to my stand alone USB supply, they all responded instantly with no interruptions, and with the same WiFi signal as before.When you say your Firestick struggles on tv usb, how does this show up.
I didn't know that Off da Grid, but yes, it makes sense so I'll give that a go thanks.Another thing you should do is force stop all the apps you use on it as they don’t shut down when you power the stick down.
The processor is then running everything and using more power so slowing it down.
How many different apps are you using?I didn't know that Off da Grid, but yes, it makes sense so I'll give that a go thanks.
That's probably why my1st generation Firestick slowed right down, and became a pain to use.
Cheers,
Jock.
Is it worth paying the extra for the 4K if you re using a non 4K TV?ShiftZZ, as advised above Dave, but I find with the 12v TV in the MH, the Firestick 4K operates better from a stand alone USB supply of around 2.1 - 2.4 amps. I don't think the twin USB sockets on the TV are powerful enough.
Cheers,
Jock.
Operationally, in the old Firestick range, the none-4K Firesticks were slower to navigate in menus.Is it worth paying the extra for the 4K if you re using a non 4K TV?
Jon
I can't remember where I got the answer from Jon when I asked the same, but basically it was a yes, as it the 4K model is faster, which is definitely my finding. Amazon do them on offer every now and then.Is it worth paying the extra for the 4K if you re using a non 4K TV?
Jon
If you asked on the forum before Autumn 2020 it could’ve been me or several others saying that.I can't remember where I got the answer from Jon when I asked the same, but basically it was a yes, as it the 4K model is faster, which is definitely my finding. Amazon do them on offer every now and then.
Ours comes in handy in the MH where conditions for the satellite dish are unsuitable, ie, weather or trees, etc. The PUCK 2 antenna also makes a difference to the incoming Vodafone signal, via the MiFi.................................however, I've not been in a remote enough area yet, to try it out to it's fullest.
Cheers,
Jock.
It may well have been yourself Kev.If you asked on the forum before Autumn 2020 it could’ve been me or several others.
But Amazon have refreshed the Firestick range. As mentioned in the post above
Have I got this right Kev, ie, are you saying that the latest 4K Firesticks, aren't as fast as the models previously available? Why would Amazon authorise that downgrade? Genuine question BTW.Operationally, in the old Firestick range, the none-4K Firesticks were slower to navigate in menus.
If you buy from the new Firestick range they’re not going to seem different.
understood. I should’ve looked at posting times.It may well have been yourself Kev.
Your post above mine wasn't visible to me, when I posted in reply to Jon.
Cheers,
Jock.
I don’t have a SMART TV so don’t know what if anything they get over the aerial source but for streaming on home internet they’d get exactly the same signal as the Firesticks and Google stick thing, etc.Can anyone tell me what's the difference between a smart TV and a firestick, just asking for a friend who is thinking of getting a FS to get a better signal than his smart TV, I say it will be the same but he disagrees.
Thanks for that Kev. If the refreshed HD version had been available at the time, that's what I would probably have gone for, with us not having a 4K TV at all.edit: oops. Missed the new question, No, in the new range it’s the HD models that are refreshed and brought up to the 4K version’s menu performance.
A Firestick (& similar) makes a none SMART TV “clever” and older SMART TV better.
But only app choices could separate abilities of the two options, IMO.
edit: implied by the “older SMART TV” comment is their obsolescence- as described by cmcardle75 below
Thanks both, he has two smart TVs in different rooms , one gets a good signal but the other in another room doesn't, he reckons a FS will make the poor one work better, so on the whole you agree with him.They do the same thing. As to which will have better signal, that could be pretty random.
However, I'd go with the Firestick, as that will be constantly updated and easily and cheaply replaced once a new shiny version comes out. A smart TV will be sold for six months. The TV manufacturer will then lose all interest in your model, stop updating the smart component and all the content providers will stop working after about 18 months as they haven't done the updates.
It's not based on a factual condition. There's a chunk of optimism in your friends aims there.Thanks both, he has two smart TVs in different rooms , one gets a good signal but the other in another room doesn't, he reckons a FS will make the poor one work better, so on the whole you agree with him.
Is that right?
Cheers.
You can, of course, put the Firestick on a long HDMI cable, so you can position its aerial for best effect. Alternatively, fix the WiFi. I guess poor WiFI round the house is just generally annoying, not just for the TV.It's not based on a factual condition. There's a chunk of optimism in your friends aims there.
Possibly, the SMART TV with poor wifi reception has older wifi hardware that could be improved by using an FS.
Or when fitted, the FS would be nearer the wifi signal & do better.
Your friend could try moving the TV, or swapping TV's, or borrow a firestick to eliminate some of the scenarios.
If they're gamblers, I'd say there is a fair chance the Firestick would help. But it is a gamble, imo
How do you force stop the apps, please?The fire stick needs a good 1amp 5v supply some TVs usb can’t supply that all the time.
Your better off using 12v adapter that is capable of supplying more amps or you may find it won’t boot up.
I haven't needed to stop apps in several years of use of Amazon Firesticks, but my usage is simple with just store apps or default apps.How do you force stop the apps, please?
