ShiftZZ
Which one for a motorhome, powder or co2?
Ditto for sure. A bit mor expensive but if needed to be used then saves lots of damage to the fabric as well as putting the fire outNeither. I have a Water Mist extinguisher, safe on a wider range of fires including electrical up to 1,000V. Dry powder does too much damage and CO2 is not to be used on A Class fires (wood, paper or anything that produces ash).
Water Mist Fire Extinguishers - For Most Types of Fire
Water mist fire extinguishers are suitable for Class A, B & C fires and safe for live electrical equipment. Free delivery on selected products. 5-year warranty.www.safelincs.co.uk
Just looked at Firetool's videos ... can't say I'm that happy with it taking longer to extinguish a fire than the C02 and that you need to get closer to the fire to use it efficiently, also that once the container is empty that's it whereas with a C02 one you can continue if needs be.I use Firetool extinguishers in both my vehicles. Compact, and safe for use on any type of fire. Fire Safety Sticks are very similar.
I also carry a powder extinguisher in the cab of my van, as a cheaper backup, and I have a fire blanket.
I did a training course with the Fire Brigade on operating various types of fire extinguishers as I was a fire marshall at a previous job.
firetool.co.uk
I think the reason why CO2 should not be used on wood, paper etc is that it can blast hot ashes out of the area which might spread the fire. I would welcome a fire experts view on why they are not suitable for as many types of fire as water mist ones.
The Firetool extinguishers (the 2 smaller ones) have a discharge time of 12+ seconds against a 2kg CO2 extinguisher's discharge time of 10seconds, so not much in it, and you can discharge the Firetools from 10' away from the fire which is plenty. If the fire is too big to fight at that distance, you're past worrying about hand held extinguishers.Just looked at Firetool's videos ... can't say I'm that happy with it taking longer to extinguish a fire than the C02 and that you need to get closer to the fire to use it efficiently, also that once the container is empty that's it whereas with a C02 one you can continue if needs be.
Not sure what's best but dry powder makes a hell of a mess and you never ever get rid of it ... ever! Nowadays the slightest sight of it by customs would ensure that you got up close and personal with some of the the Drug Enforcement officials!![]()
I understand the difference methods they use to put out a fire, it was just an observation about he time and 'distance' you need to be to use the stick as opposed to a 'normal' type of extinguisher. How do they rate against a powder one I wonder?The Firetool extinguishers (the 2 smaller ones) have a discharge time of 12+ seconds against a 2kg CO2 extinguisher's discharge time of 10seconds, so not much in it, and you can discharge the Firetools from 10' away from the fire which is plenty. If the fire is too big to fight at that distance, you're past worrying about hand held extinguishers.
CO2 extinguishers don't cool the fire, they suffocate it, which means fires can re-ignite when the CO2 expires. They can also spread the fire/embers about, effectively spreading the fire and increasing the damaged area.
I saw the Firetools at a motorhome event a few years ago, and bought mine as a result. I'll probably change them when their shelf life has expired for Fire Safety Sticks as the latter have at least a 10 second longer discharge time depending on which you buy. At the motorhome converters I was at recently, I noticed they were using Fire Safety Sticks on all their installations.
That said, I do also have a powder extinguisher in the cab of my van. It was given to me as a gift!
Fires in motorhomes/vans spread frighteningly quickly. If you need longer than you have in the extinguisher to put the fire out, you should really get out of the vehicle, even though that will often go against what you want to do. I know I'd find it very hard to leave mine to a fire...![]()
No the remnants of the powder on the floor, in the cupboards etcMel
When you say the 'sight of it' do you mean the extinguisher, or the powder remnants if you have had to discharge it?
Geoff
