Fiat X250 Ducato windscreen wipers (1 Viewer)
dixieland
88
55
Herefordshire/Eauze
since 2011
Hello Everyone,
I am looking for advice on the above before I start investigating. Yesterday when we started the van after 7 days on site the wipers would not work ( washers are ok) . There doesn't seem to be a fuse listed in the Fiat manual. Year 2011 Rapido 776FF. Any ideas?
Jim
dixieland
dixieland
88
55
Herefordshire/Eauze
since 2011
Thanks for that DBK, for 43 my book says windscreen washer (+key) anyway it is not blown.
dixieland
dixieland
88
55
Herefordshire/Eauze
since 2011
43 is not the washers because they still work when I take it out, so my book must be wrong.
So the fuse is not blown but the wipers don't work, What next?
Jim
dixieland
dixieland
88
55
Herefordshire/Eauze
since 2011
I have been through all the fuses and relays and can find nothing wrong. I would like to disconnect the wiper motor but cannot work out how to release the connector block. Anyone know how?
Jim
Gellyneck
9,235
18,210
Scotland
More than toes wet now!
Just to be doubly sure, have you only checked the fuse visibly or in a fuse tester? Have you tried the wipers with a different fuse in the circuit?
Aug 4, 2016
608
1,375
Yorkshire
Vantage Neo
Since 2003
Work backwards then, do you have voltage to the fuse if not next to check is relay T12 this supplies voltage to the motor via the fuse (same fusebox)
dixieland
dixieland
88
55
Herefordshire/Eauze
since 2011
On the other fuse box Cpl1 is good and 12v is present . I also have swapped relay T17 for another. I want to test for 12v at motor but cannot fathom out how to unclip the connector. Thanks lots for your help
Jim
Gellyneck
9,235
18,210
Scotland
Like you said, I would now check if there is power getting to the wiper motor.
Does the connector look like this?
Aug 4, 2016
608
1,375
Yorkshire
Vantage Neo
Since 2003
I'm not near my van at the moment but normally just a plastic tab lifts over the corresponding locking tab.
dixieland
dixieland
88
55
Herefordshire/Eauze
since 2011
I still cannot disconnect the motor, I am sure it is very simple but room is very restricted and it has to be done by feel. The plug is at right angles to the harness. It could well be like your picture Gellyneck.
Jim
Gellyneck
9,235
18,210
Scotland
Jim
This photo may help?
You can see a clip under the plastic shroud.
attachment.php
dixieland
dixieland
88
55
Herefordshire/Eauze
since 2011
Got it off at last. Have 12 volts between 1&2 and 1&5. Does this mean that wiper motor is burnt out or should I do more tests?. Earth wire where? Surely if I have 12 volts I must have an Earth?
Jim
Gellyneck
9,235
18,210
Scotland
Don't know if this will help?
  • Wiper instructions.pdf
dixieland
dixieland
88
55
Herefordshire/Eauze
since 2011
I have decided that the motor is at fault. I am trying to buy a replacement online from France. Whether I try a uk site or a french site they all seem to quote for oem no 77364080 left hand drive and not 77364111 left hand drive. Any ideas?
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
you have to push the connector on then squeeze the clip if you pull and squeeze it will not move you can usually here the click when they release
