Fiat Ducato fuel filter leaking
Mel
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
Can anyone help please.
arrived home with diesel leak from top of filter housing
I read on here a while back about a conversion for the fuel filter on Ducato's.
I think it was to replace the filter with a skrew on type in place of the crap that Fiat fit.
if anyone knows what part it is and part number . It would be a great help.
thanks in advance
Mel
Hi Mel.
If you pm dally he's just had a new filter housing fitted on his M/H.
He might be able to help.
Reactions: Mel
Thanks I will do that.
Mel
mel
mine leaked after a service but not until around 3 months after we had a new filter fitted all done correctly by the garage however that also leaked the garage contacted fiat and was told sometimes the seal wont reseal of these plastic filters and the best way is a new housing unit go to ebay get a complete housing for around 100 quid its easy to fit yourself
Reactions: Mel
Broken Link Removed
Reactions: Mel
NO NO NO !! they are £59.50 now if you look!!!!!!!!!!!!!!!!
EDIT or better Broken Link Removed
didnt see that 1 andy well done lol
Reactions: Mel
There has been a little price war going on this week between two sellers. This one has just dropped by a penny less and so it goes on
Broken Link Removed
Reactions: Mel
i may get 1 andy as a back up for the next time i need 1
Very wise, I have but paid £89 :cry:
Easy to swap in a few minutes with no tools if you have a right hand drive vehicle.
EDIT and have read my guides
EDIT EDIT "A" class is probably a different story
EDIT EDIT EDIT mine is always in the van and available to anyone on the road if they need it.
Mine is Lefthand drive is that a problem.
the filter is under the bonnet on the same side as the steering.
its an A class .
it does look a bit tight in there.
Mel
Parked next to a nice couple last night in an IH van conversion whose van was stinking of diesel. Yes, the dreaded fuel filter. AA man called, who tightened it up a bit more and recommended a local garage for a better fix.
its an A class .
Mel
I don't know Mel but on the standard X250 coachbuilt I had to remove the headlight to gain access.
Reactions: Mel
Sorry just read a class edit on Techno 100
No I checked earlier I can get to it via the bonnet.
will send for a new one and then fit it thanks
Mel
Once again thanks to all on Fun for the help.
Mel
We'll done techie 100
Excellent advice
I now carry a spare !!
Neill
mine is on a sliding bracket so just pull it up to release it
Andy, are these filters modified to end the leak problem ?,
Eric
No Eric but they only leak after being serviced generally
So the idea is to avoid stripping it but replace it
Even if not Eric at that price I will just change the hole thing.
what I might do is but a CAV/Lucas in line filter system before the Fiat filter and just change that every year.(if there is space to fit it).
Local Fiat Garage here in Belgium just told me its €240 + vat.
the one on EBay is £59.50 +£19:50 postage to Belgium.
thats €102.70 .
And if I dont need the motorhome before 25th October my son will bring it over.
thats £19.50 saved as UK postage is free.
Mel
Isn't it a disgrace that this problem is so widespread ?
Fiat should be ashamed of themselves.
It's not fiat but UFI who manufacture it
Similar filters are fitted on very many different vehicles
The tool was manufactured in response to so many failures
The tool prevents over tightening as it will distort when you reach the correct torque
If done in a vice without the tool then it is the casing that suffers as there is no give
So if I buy the tool £34 and in future change it myself the problom should be over.
I may also cary a spare at that price then if you have a problem you can jyst change the hole filter and your on your way.
what a great site Fun is.
Mel
Thanks Andy, ive ordered one, good luck with your Idea Mel,
Eric
The tool is under £17 these days and I've not had a leak
Dave Newell also reported that he's had no leaks since using it.
Andy where is the tool from please
