Fiat Ducato - Convert Cigar lighter to twin USB Port.
Cumbria
Burstner Solano t725
since 2014
I am wanting to convert the cigar lighter, on our Fiat Ducato based MH, to a twin USB port. There is a good video on YouTube explaining the process.....
A couple of questions arise....
1. There are three wires to the existing connector plug, black, yellow & yellow/blue.
Which of these are the + & - to be connected to the two Male spades at the rear of the USB port?
2. The video shows the original connector plug being cut off and female spade connectors being crimped to the required wires.
I would like, if possible, to retain the integrity of the original connector block and create two short wire leads with a male spade on one end (to push into existing connector block) and a female spade on the other (to push onto the relevant USB Male connector)
Anyone see any problems with this?
Barry
Thanks for the replies so far.
I am trying to avoid any "plug-in adaptors", as, of the four different USB adaptors I have tried, all of them tend to wobble about in the cigar lighter socket and often fail to make good contact.
Barry
I’ve not checked but I’d suggest the yellow with the blue trace will become live with your lights to illuminate the ring around the cigarette lighter socket.
The video is making it far too complicated, from memory you just need to drop the centre glovebox out then you can get behind the panel where the sockets are.
Also best to mod the sockets before fitting see here:-
This thread should help, which I used when I did mine.
Courtesy of Techno
The pair of original connectors have a seperate small +ve wire for illumination of the cigarette lighter socket, this wont be needed so cut off and tape back.
The large yellow +ve requires a blue female 6.3mm spade and the -ve black a red 6.3mm
Use your multimeter to see what is live ignition on and off. Then you can select if you want usb live or off with key.
Make sure you buy a decent USB socket - and make sure it's the right one for your phone! What I mean is that many modern phones need 2.1 Amps to charge and many of the twin USB sockets only deliver 0.5 Amps from each socket!
The original sockets on mine were bigger to all the others in the universe!! - I used tape around the plugs to hold them in
When time allowed, I replaced both sockets with standard sized ones and then anything plugged in (including dual USB socket) stays put
Using the above mentioned advice on here, it took about 10 minutes
I just removed the negative terminal from the terminal block, put a piece of heat shrink on it and connected it to the usb like that. Less connections and can be reinstated if required.
Single torx under cup holder inner mat and pop out small switch panel, it has a few tangs but they will come out with some jiggling. Release three (on mine) connectors for foggy lighters and switches to remove panel. Cigarette lighter comes out by pressing chrome ring tabs to allow innards to be pushued out allowing enough space for plastic bits of sockets to be wiggled out. As above 6.3mm spades into big yellow+ and black -ve, install USB socket through ciggy hole and tighten clamp nut, 6.3mm female spades to USB and put it back together.
When I did ours, I discovered that the existing connector block could be re-used! If you tease out the lighting and middle power cable from the back of the connector block, and swap their positions, then that connector block is a perfect fit and function on the back of the usb module! I also attached a note to the modified connector explaining (briefly) what I had done, in case a future owner wants to reverse the change!!
Thanks very much indeed for that.
Barry
Barry
You are right some can be pretty poor, I have one that has a decent fit and a bullish end connector, never had an issue with this one it has a pretty robust. Two outputs 1a and 2.1 a
When I did mine I chopped the wires and fitted spade terminals directly.
What you are wanting to do will work exactly the same with no issues.
I also replaced the ciggy lighter with a twist lock power socket so that I had somewhere to plug the satnav into.
The black wire is negative and the thicker of the other two is positive.
I
Just a note in favour of plug-in USB adapters. Those 2.1A USB sockets are already out of date. My phone is not especially cutting-edge, but takes a USB-C.
I know you can get a standard USB to USB-C wire, I have several of these. But the phone charges slowly from a 2.1A USB, and better from a QC3, which has a much higher power rating. It is best from a proper USB-C socket with PD.
You can buy USB sockets with QC3 and/or USB-C with PD. But my point is that it is easier to upgrade an adapter than a built-in socket.
Tha
ts how I would do it.
If you unclip the existing connectors from the block, by pulling up the plastic clips on the side of the block, then the metal connectors just slide out leaving the block attached to the illumination bulb power supply which I didn’t want to use. Then everything can be returned to standard.
Of course if you use the illumination power supply then a set of bridging wires are the answer.
That’s just what I have done. If I ever wanted I could put the old cigar lighter socket back in ten minutes. I got fed up of the cigar lighter plug bouncing out whilst travelling. Not tried this new socket whilst travelling yet. Next Friday we’re going away so it will be tested then.
Our Apple plug in 2 port USB adapter has worked well for 5 years.
Simples.
Mitch.
