I have a fiamma 65 wind out awning which needs adjustment but I’m not sure how. I’ve looked at all the online videos but can’t find an answer.
Basically when I start turning the handle, nothing moves, but if I reach up and pull the awning at either end it seems to release and the awning drops . I can then continue winding and the awning rolls out perfectly. It’s only the initial release and drop that doesn’t seem to work. I’ve greased and oiled everywhere, and adjusted the top bolt either side to ensure the awning is coming out as level as possibl, but am wondering if it’s just perseverance with the same two bolts, or is there any other adjustment I should be looking at. On winding the awning in it goes all the way back without any problem into the fully closed position either end.
