Fault codes showing PO710 PO715 PO914 PO905 P2905 Fiat Ducato comfmatic gearbox issues ?
FIAT Ducato
Hi there I have a 2009 Fiat ducato 3.0 comfmatic gearbox problem showing PO710 Temperature from (can) present and PO715 Clutch disc speed (intermittent) I'm based in the south east of England
Are they new errors or historical? Any limp mode from the engine or gear selection issues?
First try clearing codes and see if they reappear, if they do then you may need to do a 'clutch self-calibration enable' operation with Multiecuscan
:unsure: why is there a clutch speed sensor when the clutch speed directly relates to the crankshaft speed which already has a speed sensor.
Hello, and WELCOME to fun :drinks:
If you are going to reset the codes, then might be an idea to note them all down first along with any other info before clearing. Historical codes can be useful in some cases for diagnostics.
as can the freeze frame data, so a screenshot always handy (ie gromets other info)
I regularly get call outs to fix servers. The first thing they do is switch it off and switch it back on again. The problem with doing that is it wipes so much diagnostic information.
Takes a while to train clients out of this bad habit. If you have a problem contact the technician first, only reboot if he gives the go ahead.
Gromett many moons ago (97) as my work pc booted up it flashed up a warning virus found blah de blah, so i belled it, must have been late that day i was the 22nd person to call them but the first not to press any key when asked.
