Removed from m/h yesterday, fully functional. Van is 2015, so presume installed then or after.
£10 posted.
Description courtesy of Amazon:
ViewStar series solar controller is our new generation controller for off-grid solar system, such as street light, solar home system or small power station etc. The controller uses PWM (Pulse Width Modulation) technology which increases charge acceptance of your battery and extends its lifetime. PWM technology can also recover some lost battery capacity. This solar charge controller adopts the most advanced digital technique, displays on the LCD and operates fully automatically. LCD display can show various charging parameters e.g. voltage and current for the solar panel and battery.
Specifications of PWM 10A:
Electrical parameters:VS1024N
Normal system voltage:12V/24V auto work
Rated battery current:10A
Max. battery voltage:32V
Self-consumption:18mA
Communication:TTL232/8pinRJ45
Equalize Charging Voltage:Sealed14.6V;x2/24V Flooded14.8V;x2/24V
Boost Charging Voltage:Gel14.2V;x2/24V Sealed14.4V;x2/24V Flooded
No box, manual,cables or screws.
Stock image below
£10 posted.
Stock image below
