Electrified my Friends Bike
Ormskilrk
Swift Voyager 685FB
A friend hit a pot hole a year ago, came off her bike and broke shoulder, collar bones, wrists etc. She wanted to get back on her bike but having lost fitness and Liverpool demolishing the Churchill Flyover so she had no easy route to get to work. So the obvious answer was to make her bike an ebike! I ordered the kit and battery from Austria on a Sunday night and it arrived on Wednesday morning! I can't get things from Manchester that quick!
Anyway.....£380 and 4 hours of work and off she goes. When the fitness has improved she intends on upgrading her bike anyway so will have the choice of ebike for lightweight road bike.
Powers up!
Battery in Place
Had to make a stainless steel bracket to hold the pannier.
Electric wheel on
All done.
Looks like you’ve done a really good job there. (y)
These are the ones I use
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=223887649276
And when ebay have the 5% or 10% discount one they normally qualify for that too
Available with 26' or 700c wheels, cassette of freewheel fit
That's the same supplier I used. Good prices and quick shipping.
I bought the battery and kit separately as a downtube battery would not have fitted well. Easier with a pannier and she can put a bag on it for shopping when out in her motorhome.
Nice job, I keep thinking about converting my old Specialized with a crank drive conversion even though we have e-bikes.
I notice those are 350W so can't be used on the road.
They can but you'd need to insure & tax them to do so.
Just been to look around our local Argos clearance centre in Walsall. They have a few folding 24v e bikes at £279.
I built one on a Giant alloy frame about five years ago. Motor wheel bought second-hand, controller and battery new. The battery came with a mounting & the controller I fitted into a polished alloy cylindrical case (an old air ram machined to suit). All wiring is on plugs into the case. As has been said the real issue is keeping it all tidy. Battery & controller fit within the 'triangle'.
Yes, offroad only
Here's my single speed retro Marin that I built up to try a conversion out in it's natural habitat
And a Cannondale that I've more recently converted
And a Tern folder with a 250w conversion for the van
250w are available.....
Front wheel...
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=223560744662
Rear wheel...
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=333527529972
Is there any particular reason you went for rear wheel drive rather than front wheel?
I'm think that front wheel may be a little easier. Or am I wrong in this?
Report back from my friend....she lives at the top of the hill below and loves the assistance! She's going home from work early to give the bike a ride along New Brighton front. Without the ebike kit it would still be in the shed!
The front wheel is easier. However I would rather be pushed along than pulled. For muddy conditions the weight is also more on the back wheel so better grip.
The only thing harder about the rear wheel kit is that you have to remove your gears and install them on the new electric wheel. They do supply the tool for this in the kit though.
Just one more question, please. The vendor states that there is no duty payable for EU countries. Do you know whether we have to pay duty now?
And I've never seen paid duty either are we still in the transitional period
As regard front or rear wheel drive, definitely rear wheel drive, the front wheel drive ones I've built will quite easily spin their front wheels in the damp, which can be rathe unnerving
Front wheel drive are a bit weird to ride as they pull you along, for getting up big hills crank drive is best.
This would be ideal for dragging our 35kg mutt around, are they available for bikes with hydraulic disc brakes?
This is what we use our e-bike for, 2 dogs in the trailer, mush easier with some electrical help. Ours are about 18kgs each so about the same as your single large woofer:LOL:
Yes, all they hub conversions I've used have the 6 bolt disc pattern,.
The cannondale I did in my picture above had shimano hydraulic discs, obviously you can't use the brake levers that come with the conversion, so you'll loose their motor cut out facility unless you then fit aftermarket Brake cut outs to the hydraulic lever
