Electrics …. Am I missing something…? (2 Viewers)
Just smiffy
May 31, 2015
11,689
44,554
Ducato PVC
Getting Better
I have discovered it has a relay … therefore that does not compute in my head so it’s off to the sparky…😆
Just smiffy
May 31, 2015
11,689
44,554
Ducato PVC
Getting Better
Not enough leccy Smiffy, even for that excuse of a horn. Bobbie the Hobby has three Steble horns to wake the dozy bar stewards up :rofl:
I’ve got an uprated 70amp alternator…..😛
Sep 10, 2012
2,133
3,714
worcester
Sunliving van
Just smiffy have u given up on this and found an auto sparks?
I would try a bulb in place of the horn to prove the curcuit. Start with a side light then indicator bulb then headlight.
You have the volts but maybe not enough amps for the load as has been said.
Aug 18, 2014
23,806
133,945
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
It could well be the fuse blown. Shows ok on meter as it as a slight feed but when current is required it dies.
11,956
16,571
The biggest problem you have is using a multimeter. Use a 21w flasher bulb as a test lamp to prevent misleading results. A multimeter is of very little use when faulting circuits carrying more than a few milliamps.
Grummyb
714
2,205
Corby
Since about 2013
I'm going from memory here (and a bad 1 at that) but I think old minis work with a live at the horn and no earth and the horn button actually makes the earth circuit when pressed
Just smiffy
May 31, 2015
11,689
44,554
Ducato PVC
Getting Better
I’m going to have another fiddle with my horn today (‘that’ll please Badknee) as the sparky’s is closed ….
Just smiffy
May 31, 2015
11,689
44,554
Ducato PVC
Getting Better
Isn’t it amazing what fiddling with your horn can produce, all fixed..😁 it was a dodgy connection in the wiring loom behind the little dashboard, I found it by taping the horn button down while fiddling with anything and everything and it sounded when I bent some wires there..👍🏼
I’ve noticed a few other wires are brittle so it may need a new complete loom in the not to distant future…😳😩
thanks again for the help..👍🏼
