Electrical power upgrades, which order
sidaorb
Dont know yet
Newbie
Following on from my inverter thread and the subsequent can of worms I'm to get a bit more advice, of all the bits listed below if I was doing a bit at a time which order would you all suggest, or which if any aren't worth doing without another etc.
1) Second leisure battery
2) B2B charger
3) Solar panels
4) Anything else to add?
Still trying to work out if I do need the inverter, so initially the above list is based on 2-3 nights wild camping, gas fridge/hob/heating.
Running TV, lighting, CPAP machine, phone / laptop chargers, 12v modem
Thanks in advance
2) B2B charger
3) Solar panels
I think that's about the right order. It depends on your lifestyle. If you like to move on every 2 or 3 days then a B2B is number 2. If you prefer to drive to a site then stay for a week or two, move the solar panel up to number 2. Either way, a second battery is number 1.
Agreed.
Ian
I would say batteries and solar first if you like wild camping. I have just bought a B2B after 3 years of wilding with only solar panels, but I'm still not sure it going to be beneficial to me. A 240V inverter is only necessary if you want to watch a larger TV/ soundbar, although 240V TV's are cheaper.
Are all your lights LED ?
Do you use a humidifier with your cpap? It makes quite a difference to the power consumed overnight. With humidifier and other demands such as lighting, recharging pads/phones and a bit of tv I use about 30 AH per night. In summer 2 x 100w of portable solar keeps up with demand but the b2b does the job in less than an hour on moving on days.
No humidifier thankfully.
Hence why not sure about solar Vs B2B probably to start with we'll be moving maximum every other day, so thinking b2b over solar to start with.
How do you find portable solar aren't you worried some bugger swiping them?
You can put a cable and padlock round them, but at the end of the day a lock will only keep out an honest person. If a thief wants something then they will have it no matter what.
With the lower power needs of a cpap without a humidifier and your frequent moves a b2b would be my first choice too.
Not had a problem yet with portable solar going walkabout but I only bother with them when staying put for many days. If I think the location makes them particularly vulnerable I put them flat on the roof, secured with bungees to suction cups, to stop them blowing away. They are lightweight semi flexible ones which are easy to move around. However, now I have a good b2b I don’t find much need for them.
2) B2B charger
3) Solar panels
Thanks in advance
As per all the others, however under anything to add I would (have) buy a couple of banks of electricity which can if you want charge up through solar
Any of these will do the job for well under 20 nicker and you will have 4 full phone charges spare.
https://www.ebay.co.uk/sch/i.html?_...harger.TRS0&_nkw=solar+phone+charger&_sacat=0
We take ours with us when out for the day on the motorbike just in case maps.me runs my phone dry or wo betide my electronic cigarette runs out. Leave it on the beach and its charged in no time.
My choice would be an extra one or two batteries first then as much solar as you can fit on the roof with a decent MPPT regulator such as Votronic or Victron.
Don't say what van you have, if a German van it will have correct size cabling and a B2B won't give a lot of a advantage over the standard split charge set up. If a Brit van probably worth fitting a B2B.
The first upgrade may be some decent battery cables, at least 10mm2 from the leisure battery to the alternator, ideally 16mm2, and then between the batteries and an inverter use 25mm2.
Plus be a bit fussy about making sure all connections are clean, tight and protected by at least a smear of vaseline or some ACF50 dribbled on.
Of course you may be lucky, but copper is expensive so that's the first thing to look at. As always with thick cables - make sure they run without chafing and vibrations will never cause them to short out.
You would probably need to change the split charge relay as well
I have 3 x 125AH batteries and a 300w solar panel on the roof through a Voltron MPP350 controller. I recon that from the begining of March to the end of October I am completely self-sufficient. (I do a lot of CAMC rallies, most do not have hook-ups). Even at New Year, in the worst of weather, I can last a minimum of 7 days. That includes moderate TV, and blown air heating fan.
Peter.
Some vans come with BtoB but if not it is the cheapest 'add-on'.
For my own taste Solar panels enable camping on Aires. B2B distributes the free energy, extra batteries allow you to store more power.
I would hate to be without GasLow or similar. The thought of running out of gas outside of the UK would not be fun. I do not know of any country outside of the UK that uses the same gas as we do but Autogas can be got anywhere and is much cheaper than exchange bottles.
Have you bought a van yet?
Deposit paid but not collecting until mid May
It is an old VW T4 based Compass, so very old tech, hence trying to avoid going too OTT
a 12v supply for your c-pap will help a lot. if its one of the small re-med units a laptop power supply works well
Already have the 12v power unit for it thankfully.
