Peggysue123
- Mar 18, 2021
- 4
- 1
- Peugeot Boxer camper
Hi, anyone know why my electric step has become sluggish and reluctant to move even when on mains?
They need regular cleaning and liquid maintenance (oiling)......................... at least annually.Hi, anyone know why my electric step has become sluggish and reluctant to move even when on mains?
What about GT85 please?Whatever you don't use WD40, they have nylon bushes, WD40 will make the bushes swell.
And that is the advice of the fitters at Thule/Omnistor factory in Menen, for the step and the awning.I just use a silicon spray on mine.
WD40 is a good releasing fluid, but not a long lasting lubricant, as it dries out. I used touse it on all my key locks on the car, until I was advised by a mechanic that after freeing the lock with WD40, I needed to then lubricate it with fine oil or silicone.Oh dear, I think I did use WD40
Don't worry about it, just get some silicone spray and do it again with thatOh dear, I think I did use WD40
Best to use graphite on locks Ambersil Locklube is good.WD40 is a good releasing fluid, but not a long lasting lubricant, as it dries out. I used touse it on all my key locks on the car, until I was advised by a mechanic that after freeing the lock with WD40, I needed to then lubricate it with fine oil or silicone.
Just give every joint a good dousing with silicone spray, which should push replace the WD40.
Cheers,
Jock.
Can I not just rub the key with the grahpite from a chippy's pencil Lenny?Best to use graphite on locks Ambersil Locklube is good.
Only if it's an HB. B leaves an awfy mess!Can I not just rub the key with the grahpite from a chippy's pencil Lenny?
Jock.
Coincidentally, Peggysue123 Lidl's got silicon oil on offer next week.I used Silicon oil (Aldi or Lidl stuff) on ours.
