is there anyone i can talk to about an electric problem with my auto-trail it is plugged into the mains at home but there is no display above the door iam a new motoahomea help please
The beeping is telling you there is problem. If the problem is a low battery, try leaving it for a couple of hours for the mains to charge it. Have you checked the connections to the leisure battery? They may have come adrift.fuse 8 ok the display keeps beeping and it is saying battery very faint but still not switching on
We had this display on a previous Autotrail Tracker. It failed once, and found that there is a reset button behind the display facia. Carefully taking off the square frame reveals the button. It may be worth a try.i have power from the house on but if i press any buttons nothing happens there is a faint display and a beep i am on the mains
Yes, sorry, my previous post was wrong, I was confusing two vans! We used this remove plug method to reset on the AutotrailWhen I had a beeping panel and no legible display I carefully removed the surround (think it unclipped). Undid the screws. Removed the cable from the back. Counted to 10. Plugged back in and hey presto. All working. batteries weren’t empty but they was a problem that tripped the ehu out. This process was recommended By another fun step somewhere I think.
i have the same system in a 2003 autotrail. Hope this helps
