Electric hook ups (1 Viewer)
Sep 18, 2015
698
702
Selby, North Yorkshire
Rapido 8066DF
A query re hook ups on camper stops, you plug in your cable and connect up put money in a prepaid meter when the money runs out and turn off can the cable still connected drain the leisure battery as mine are dead in the morning on site in Germany
Regards
Bill
May 31, 2015
11,688
44,546
Cornwall
Ducato PVC
Getting Better
When you say dead, no power at all..? Could be the money running out has tripped a switch or blown a fuse...
BILL 875
Sep 18, 2015
698
702
Rapido 8066DF
There are 2 leisure batteries problem 1charged batteries on site drove 3 hrs in sun arrived at stop L B's very low showing charging from alt on panel, charged up by mains, next day the same driving plugged in on site charged for 8 hrs went to bed every thing turned off, far this morning now plugged into mains and charging ok the leisure batteries are 18 months old as new motor home it does look like batteries
Bill
Oct 2, 2008
4,476
7,964
Salopia
Duro 6x6 Overlander
since 1968
Bill
You need to charge batteries then disconnect , allow an hour and then take reading , if connected to mains , charger , engine running , or solar, reading is pretty much useless.
BILL 875
Sep 18, 2015
698
702
Rapido 8066DF
Okay will do that but I'll take the fuse out of the solar reg to stop that charging when checking although the solar regulater is showing fully charged but L B's can't be charged after 2hrs can they?.
Lenny HB
53,493
150,287
On the coast in West Sussex
Hymer B678 DL
Sounds like the batteries have had it, if the van was bought from dealer stock the batteries could have left discharged for a time which will shorten their life, or if they are AGM's probably done well lasting 18 months.
Need to separate the batteries then test each one.
Best way of testing a leisure battery is to fully charge it, let it rest for an hour then & check the voltage:-
1) Place a load on it of say 5 amps (can do this in the van by turning on lights etc.).
2) Leave it with the load for a time that equates to 25% of battery capacity (100A/H battery it would be 5 amps for 5 hours).
3) Turn the load off let the battery settle for ½-1 hour measure the voltage, the battery will now be @ 75% state of charge.
4) Repeat 3, battery will now be @ 50% state of charge.
5) Repeat 3, battery will now be @ 25% state of charge. - not recommended to take a wet cell (standard battery) below 50% too often.
6,876
8,002
Manchester
A class Hymer
Since the 80s
This is how to test a brand new battery. If it's deteriorated and has a reduced capacity, it's a bit different.
3) Turn the load off let the battery settle for ½-1 hour measure the voltage. Use the table below to find the % discharge. A new battery will now be @ 75% state of charge, but a used battery could be maybe @ 60% state of charge, and a bad battery could be @ 30%.
Similar for steps 4 and 6 (what happened to 5?)
11,844
14,080
Eastbourne East Sussex
Hymer low profile
Since 1972
If its a new purchase from a dealer then the batteries could be older than the motorhome. When I bought mine the vehicle battery failed after a short time and when I looked at it it was badged as Fiat (in a Mercedes motorhome) so plainly not the battery that belonged to it. I believe some dealers remove the batteries from their forecourt stock and so it may be pot luck on what goes back in.
Dec 28, 2015
1,165
8,098
lake district
low profile mh
Since 2015
Regards
Bill
Hi bill . John says once the power has turned off it’s not connected and can’t drain the battery
Regards sue
Apr 27, 2016
6,876
8,002
Manchester
A class Hymer
Since the 80s
It's most likely to be a bad battery, but a charger fault can drain a battery.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Did you switch off the Media ??
I have left it on overnight and woke up to nearly dead batteries ! !
Mitch.
BILL 875
Sep 18, 2015
698
702
Rapido 8066DF
Turned all 12 v off at bedtime only left switch on so mains would charge till about 3am at 8.39 switched on 12v L B's would not even turn water pump back on mains all ok again will stay on 240v when overnighting to get back to Uk.
Bill
Lenny HB
53,493
150,287
Hymer B678 DL
As you give 2 batteries have you separated then to check it is not one faulty one dragging the other one down?
two
Aug 4, 2011
4,906
4,577
West Midlands
A-Class Fiat
To answer your question, EHU will not drain your batteries.
I suspect that both are knackered and need replacing.
BILL 875
Sep 18, 2015
698
702
Rapido 8066DF
I have borrowed a multi meter, tested one battery o.oo v tested other battery 10.5 v put best battery on charge for 2hrs went up to 11.6v and straight down to 9.5v so I assume from that both batteries are shot is the conclusion.
Many thanks for all the replies.
Bill
BILL 875
Sep 18, 2015
698
702
Rapido 8066DF
Update two new batteries fitted on friday as well shot after a full nights charging 1 batt 5.7v the other 7 .5v all charging circuits were ok so just shot. only 20 months old so claiming on warranty.
Bill
Dec 28, 2015
1,165
8,098
lake district
low profile mh
Since 2015
Bill
Glad you got sorted Bill , expect to last more than that
