M-J
- Jan 15, 2019
- 2,576
- 6,237
- Bessacarr E562
- Enough
Are the ecocamel shower heads any good?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Looks to work quite well in this quick demo;
Hi Langtoftlad, we have a trigger shower head. What worries me is that the tap is pumping all the time. Does it switch off at the trigger in the same way as the pressure system works on the tap? Hope this makes sense.Didn't do it for me... now have a trigger shower head.
Yes, I also think such shower heads are better than Ecocamel, especially in low water pressure areas. Ecocamel doesn't seem to be able to provide enough traffic, and it can be a bit noisy. The seoul stone I am using is quiet in the shower, increases water pressure and saves more water.I hve just fitted a ionic stones pressurised shower head ÂŁ7.90 ebay together with a chromed brass ceramic on, off thumb lever about ÂŁ2 from China. Works brilliantly but heavy so best not to leave it on the bracket when travelling I just leave it on the floor of the shower
Is this a sales pitch I wonder. Quite odd for a 1st post and to pull the thread up from 10 month ago.Yes, I also think such shower heads are better than Ecocamel, especially in low water pressure areas. Ecocamel doesn't seem to be able to provide enough traffic, and it can be a bit noisy. The seoul stone I am using is quiet in the shower, increases water pressure and saves more water.
A pressure system will switch off, a microswitch system will not.Hi Langtoftlad, we have a trigger shower head. What worries me is that the tap is pumping all the time. Does it switch off at the trigger in the same way as the pressure system works on the tap? Hope this makes sense.
