Chris CM
My Devon Aztec PVC is fitted with a Sargent EC155 PSU/charger.
It has 2 x 100w solar panels supplying 2 x 95Ah leisure batteries via a Victron 75/15 mppt charger, the vehicle battery is kept topped from the leisure batteries with a Sterling battery maintainer. The output to the leisure batteries, via the EC155, when the engine is running seems rather low, about 6A, I have a Ctek battery to battery charger (D250S) which would give far more efficient smart charging, up to 20A, but I’m unsure as to how to wire this with regard to the EC155’s connection to the vehicle and leisure batteries. Do you think it would be ok to parallel with the EC155 charging and connect the Ctek directly between the vehicle and leisure batteries?
Thanks.
Thanks.
