I have attached the EC200 spec. I have the same unit. My solar I connected to my hab batteries via a mppt controller. As far as I'm aware there is no input for solar and if there is it will only support minimum wattage. I don't know why a separate battery charger has been added unless the integrated one isn't working.any one know if i can connect solar panel to this .just got the van and it has a duritc 20amp automatic battery charger wired into the ec 200 box .seems unusual.
The leisure batteries should be charged while the engine is running via the split charge relay. The solar will still charge also if wired direct via a controller.thanks for your reply seperate battery charger i think that its something to do with the 240 volt supply . i just connected solar straight to leasure batts. do u know how to get 12 volt supply going to habitation when engine is running. thanks
no i didint receive ,The leisure batteries should be charged while the engine is running via the split charge relay. The solar will still charge also if wired direct via a controller.
P.S Did you receive the EC200 spec I sent.
Phil.
could u tell me what it isThere is a mod you can do to get your hab electrics working while driving.
When I finish work I'll send you the info sheetcould u tell me what it is
What do you think of thisAttached PSU 2007 sheet.
Looks like the EC200 built in charger has failed and a replacement has been wired into the unit to maintain the working features of the power supply unit.
