EBL 101 battery selector switch
Malvern
Hymer B525 2006
I have great difficulty seeing the switch for the battery selection as the EBL is under the paddenger seat (RHD) so I took this picture:
using my mobile. Am I right in thinking that it is set to gel? The reason I ask is that the batteries fitted (since 2012 by the previous owner) are Humax LV25MF which are described on-line as sealed acid batteries. Certainly there is no option of topping them up. Is it right that these are being charged on the gel setting? I read somewhere that the charging regime for gel is different because they are sealed and so cant gas off so wondering if this is the case for these batteries?
Paddy
Thanks @Hettie's Crew -I wasnt sure whether the switch was in the up (gel) or down position (lead/acid) -I thought maybe the red bit of the switch signified off and the black on but couldn't really tell from the picture! (mobile phone cameras are pretty amazing really so I shouldn't complain! )
If you have a solar regulator there might also be a battery setting on there.
Thanks @Theonlysue - I don't think I have a separate solar regulator - just the EBL101 with its solar ports (so the control panel over the door shows my solar current). If I do I have no idea where it is!
