Hi.
I have recently bought a Niesmann Bischoff Flair 6700.
I have installed a Duocontrol on my gas tubes.
I bought a sensor for indication when it switches to the spare bottle and also an Eisex heating unit for preventing the regulator to freeze in the cold part of the year.
But I want to connect both the reserv switch and Eisex to my existing panel CBE2005. Not to a separate panel, which I know exist, that would be the easy way, which I am not prepared to walk yet ?
Has anyone done this kind of installation this before?
Are there any tips and ideas on connection?
Does anyone have a wiring diagram showing how to connect and where the involved duocontrol connectors are placed in the vehicle etc?
One should eg connect the pins 5 and 6 on a contact at CBE2005 together. Don't really understand why and how?
There is also a loose green cable behind the Cbe2005 which is marked "Duocontrol" .
I don't understand how to connect it to the CBE2005 panel though ?
I have found a three-pole connector under the sofa (where the gasol goes into the car) and it is marked "Duocontrol", but I do not really understand how to get it together with the loose green cable behind the panel. The Eisex positive from the control button goes into the three-pole connector when I measured, so the Eisex part I might be able to solve.
But the microswitch that sits as a sensor in the gray hat on the controller I do not understand how to connect to the vehicle and to the cbe2005 panel.
Is there anyone who has a wiring diagram on the above eg.
All help is gratefully received.
Br Per-Olof
Br Per-Olof
