ducato 3.0 mpg
Jul 23, 2015
25
Bristol
c class
Hi everybody, I'm not one of those m homers that gets paranoid about mpg but after switching the in dash reading on I was a bit shocked to find my 2009 3.0 tri axle bessacarr returning 17-20 mpg on the motorway at 60mph, compared to my previous 2005 2.8 ducato always around 25-30 mpg ? is this the norm or is this a bit low?, rgds Kevin
Jun 24, 2019
351
456
Dethleffs Globebus
Was your handbrake off ?
But seriously, remove any excess weight that you are carrying.
eg, water, stuff in the garage not being used etc
E
Jul 23, 2015
25
Bristol
c class
van was running fairly light, very rarely run with much water, as for removing excess weight she who must be obeyed will be properly pissed at catching the train. if 20mpg max is the norm then what will be will be but I was a bit disappointed compared with the old 2.8.
TerryL
4,282
4,089
North East
Low Profile
Try dropping the speed by a couple mph - although we're not a tag, found the mpg improved noticeably when I cruise at 58mph (i.e. just above the trucks) rather than 60. The overall travel time difference is negligible, but you do have to concentrate for a bit until you get used to it. Also I only use cruise control when the roads are reasonably level - when climbing and descending the "lag" on the CC tends to make the engine work harder IMO unnecessarily.
May 31, 2015
5,441
8,450
Cornwall
Hymer B544
An expensive experience.. still..!
As Terry said drop a few mph and it will make a difference, you could get the mrs to push you a few miles and that will up your mpg.....šŸ‘šŸ¼
May 14, 2013
91
99
Pevensey Bay
Carthago Compactline
Yonks
I used to have a Hobby 3 litre tag axle which averaged 31 mpg.
Mr B
836
1,727
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Our 3.0 auto does about 28mpg at 65mph on cruise, running weight usually close to max 😜
Dec 31, 2010
286
317
Sunny South Shields
Dethleffs A Class
Since 2010
We average 24mpg fully loaded 8.25m tag these figures are just using the dash figures and normally cruise at 60mph.
BwB
826
837
Suffolk UK
PVC
Since 1990
2000rpm is the sweet-spot for many diesels, I find. For most Fiats this seems to be about 55mph(ish) in top gear.
Sep 21, 2007
386
225
Essex
11.5 years
Normally in good driving conditions we get between 20 - 22 with our tag c class. Best was just over 23. Towing car on A frame we get between 18 - 19 most of the time. (y)
Oct 31, 2013
583
806
Conwy
C class
20 years
Try doing a physical fuel consumption check as against the trip reading. We averaged wimpy with a 3ltr tag but it varied considerably due to various conditions
SMC Motorhomes Newark
Johns Cross
Safeguard Motorhome Insurance
Rhino Installs
Friendly professional service from qualified technicians
Free Club Stickers
