I'm not sure whether it is related to adding a mattress topper and bedding, or clipping a kerb with a front wheel, but our drop down bed has developed a habit of dropping whilst driving. We have a A class Carthago 4.9.
Looking at the mechanism, there doesn't seem to be much to adjust:
There is a locating pin behind the guide plate (2), which drops into the white nylon block (1). There is a gas strut (3), but I don't think it has anything to do with locking the bed in position. The block (1) is on a plate that is bolted to the frame, this can move sideways at bit. This seems to be the only adjustable available.
The depth of the locating pin (1) doesn't seem to be adjustable. The nut on the rear (2) is to adjust the release cable tension. It has a little slack on both sides, so is not pulling on the pin when the bed is in the up position.
The extension of the locating pin is the same as the depth of the hole in the white nylon block, on the other side the extension of the pin is 9mm, so nothing much in it.
Am I missing something? Is there anything else to adjust, or that can be done? The white nylon blocks have a little wear, where the pin drops into them. Would replacing these make a significant different difference?
Is it practical to shim the back of these blocks?
All suggestions welcome.
Thanks, Ian
Thanks, Ian
