Drainage
shirley cross
suffolk
a class
30 years
Just picked up our new Rapido. In their wisdom have changed the drain to well under the van with pump to dump the water. Sounds great except when you have mains drainage and want to attach a pipe to lose the water. Anybody got a solution. I believe you may be able to buy a part to take the pipe to the side, hoping for an easy solution rather than a trip back to the dealer.
You can buy all sorts of pipe and pipe suspension stuff at a plumbers merchants.
The pipe size would probably depend on the existing outlet size. 21.5mm overflow pipe is cheap and has all the fittings 👍
