Dometic fridge/freezer not working on gas
Oldgustaf
Far west Wales
Dethleffs T6501B
Since 2019
We are off grid in west Wales. We have gas, the gas is turned in, we heard the normal 'clicking' before ignition, the gas light is glowing normally and the fridge is on highest setting. But the fridge and freezer are definitely not cold (ice cream has melted). Was working fine at home on 240v. Any ideas what's going on?
The usual suspects are: if the flame is good, blue and steady then the flue may need cleaning, the burner or baffle may have moved
Thanks! How do I inspect the flame and see whether the baffle/burner have moved? Is that don from outside?
Thanks Mr Ex Gasman. I'll have a look when we get home later today. Final question: upper or lower vent?
Also try it on a lower setting, sounds strange but this is how they work...
Our last one ran best set at about a quarter 👍
I don't know why but it is often said that you get a colder fridge freezer with the setting one notch down from maximum. This works for us!
We use two pips down from max to get the coldest :)
Also, it is that time when you need ve nt covers going on
Carefully if using vent covers on when using gas.....can get VERY hot behind top vent unless your chimney exhausts through vent and not to back off fridge.
Thanks everyone. Going to try setting two notches up.
We solved our problem by turning the freezer upside down and banging it
YES I KNOW IT SOUNDS CRAZY
But it is well known amongst salvage yards and repairers.
The principle being that the tubes carrying the coolant around become blocked with some gunk
and the fluid cannot circulate correctly
Turning the fridge upside down and giving a good bumping in the process dislodges the gunk and clears the
tubes allowing circulation to re-commence as normal.
Yes it worked for us
I used to repair fridges and this does work, but the OP's fridge works on electric so not the problem here
Agree about not running at highest setting. Not on our fridge but we had a problem with the oven over time our pilot light had moved slightly and didn’t allow oven to stay on. Not very technical answer but might help
Hi Gasman that's fair enough I bow to greater knowledge than mine
It is correct - works perfectly on electric (12v and 240v). Took Gasman's advice and removed lower vent. It was a bit grimy in there (almost 10 years old). Discovered flame box bottom right. Removed cover to reveal steady blue flame. Had a bit of clean up in there, put it all back together and fired it up, two notches below max. That was several hours ago and neither fridge, nor freezer are feeling cold. Blocked flue maybe? Is that accessed from top vent? BTW, had thorough habitation check 16 months ago when we purchased it - but don't know when last habitation service was.
Yes, good point. Need to find good hab engineers in far west Wales. Any recommendations?
Just a long shot but anything to do with it needing re-pasting or not level ?
We're back home now and mh is in barn on level ground. Fridge on gas but not getting cold. Don't know what re-pasting is.
Re pasting is re application of thermal bonding past to the fins at the back of the fridge, if the fridge is over 10 years old it can help, but again if it works on electric it's not that
Its usually the jet partially blocked ten minute job there a video on utube how to
You can have a nice looking blue flame, but if it's not making a "roaring" sound, it'll never get your fridge cold. As mitzi says, get yourself on YouTube and check out videos of jet cleaning.
Flu cleaning
BEFORE trying to clean the flu
Trun the fridge off completely and let the burner unit cool down then cover the burner unit and everything below with a clean rag. Cleaning the flu means loads of crap drops down into the burner unit area
SO COVER THE BURNER
Ease of access to clean the flu depends on the make and model of vehicle.
it can be very easy
it can be a slightly more complicated
it can be difficult
It may mean you want to sell the vehicle instead of cleaning the flu :laughing:
Remove the upper and lower vent grills (usually just 2 bayonet buttons turned with a coin)
We have a Dometic fridge freezer
the flue is simply a chimney pipe surrounded by an layer of insulation
At the top of the chimney is a hollow cowl cap which directs the waste fumes towards the outside louvre vent.
This is held in place by a small philips screw. These rust up badly so soak in in WD40. and then try to remove it. it may come out easily it may not, your arm and hands may need to amputated set on gimbles and re attached to get the screwdriver angle so you can remove it
Dont drop the screw
Lift off the chimney cowl and then hanging down inside the flue is a piece of wire with a twisted Baffle (piece of aluminium) hooked on the end. LOOK carefully how it hangs in the chimney before removing it. This piece of aluminium ensures the hot rising waste fumes twist as they flow upwards helping the wast fumes to escape more easily.
Now you can clean the flue. A bottle brush is great or an old toothbrush fastened onto a long cable tie
you can twist it as you insert it into the flue and ensure you brush all the walls inside the flu.
Re-ang the wire and aluminium baffle. Before fitting the Cowl I hacksawed the hole (that the screw went through) into a slot. This meant I could half screw the screw in then slide the cowl into place and then tighten the screw. IT WAS WAY EASIER than juggling screw and cowl at the same time.
Finally hoover the crap up at the bottom of the flu Ensuring you hoover the jet burner unit as well.
Relight the fridge
re fit the vents
and pray
I am not in anyway trying to teach grandma to suck eggs but when I have done jobs i always wish someone gave me an idiots guide rather than assuming I know what things are and what they do.
I hope this helps
Kev
Hi Kev, I was just beginning to think that it's most likely a dirty flue that's causing the problem. I'd pulled out the burner (albeit still connect to gas supply pipe), inspected it and cleaned it. Then lit it (forward of the flue). Nice, strong blue flame. But when I reassembled it and lit it, the flame was far less strong. Unfortunately - and I'm kicking myself for this, I managed to snap off the head of the small grub screw that holds the burner in place beneath the flue housing. I don't think the burner can become dislodged because the threaded part is still in situ but I'm not sure I want to take the risk. So I'm now searching the Internet for a Dometic 7855L burner. I might try drilling it out first but there's nothing to get purchase on to twist it out. What a bugger.
But THANKS VERY MUCH for your idiots guide. This will be incredibly useful when I do the flue. Next job. And will give me a laugh when I read it again!
Oldgustaf
When I went to clean the jet on my fridge, my screw also broke the same as yours. I drilled my broken screw out, tapped a new thread and used a better screw. It’s not too difficult a job (y)
Trevor
