NorwayNeil
I am looking at buying a 2017 Sunlight T66 and trying to find out if it has composite/bonded walls. TIA.
Its not a simple question, there are quite a few variants in wall construction techniques, The best imv is a sandwich of PU Foam totally bonded with a decent layer of aluminium outside and in, or in some cases GRP, they are a lot stronger than traditional construction offer high levels of insulation and most importantly timber free.I am looking at buying a 2017 Sunlight T66 and trying to find out if it has composite/bonded walls. TIA.
Hello, we have the T66.Yes, twin skin with a polystyrene inner core. The internal skin is a composite fibre timber sheet about 4mm thick. 30mm of foam. Plus outer ally/ ABS skin.
I have carried out various upgrades to ours which may be of interest should you complete the purchase.
Regards. Mike.
Hi Mike, Thanks a lot, where did you find that info out of interest? I've been looking/asking all over.Hello, we have the T66.Yes, twin skin with a polystyrene inner core. The internal skin is a composite fibre timber sheet about 4mm thick. 30mm of foam. Plus outer ally/ ABS skin.
Regards. Mike.
That's one way to find outView attachment 620245A picture speaks a thousand words. This is my 2017 T60.
No, a gas bbq point.That's one way to find out. Were you installing a tumble dryer?
Wow, well done. Do you have any posts or links to your projects? If not, I'm offering tea and biscuits whilst you demonstrate on mineNo, a gas bbq point.Very happy with the build quality of my Sunlight. I've made lots of additions including additional solar, extra power points, fridge fans, and the latest one is adding central locking to the Hab door. Love tinkering.
It's closed cell, so liquids wouldn't migrate into it.Hmmm polystyrene not the best choice of insulation if it gets wet.
Incorrect I'm afraid - watch this video.It's closed cell, so liquids wouldn't migrate into it.
Not much of it left! You’ve modified the hell out of that vanView attachment 620245A picture speaks a thousand words. This is my 2017 T60.
Correct, Carado and Sunlight are both Budget brands owned by the Hymer/Dethleffs Group.Good vans for a budget model, the timber frame and polystyrene insulation is not ideal but not a deal breaker.
They are built on the Fiat chassis cab rather than the Camping Car chassis, means they roll a bit move on corners but you get a lot more ground clearance.
Any info you find on the Corado is relevant as it's the same van just different branding.
That is the trade off with German vans better build quality but you have to spend on optionsOur recollection was that the build quality in the Sunlight was better (it just felt more solid, if you know what I mean) but the equipment spec on the Benimar was much better for a similar price.
Hi NHi Mike, Thanks a lot, where did you find that info out of interest? I've been looking/asking all over.
We bought this very clean 2017 model yesterday, drove it 150 miles home, no problems but still getting used to the Comformatic.
Yes please, would very much like to hear/ see what you've done to yours; side chat or continue in this thread?
Hi Neil, my information came the same way as Sean's, who has also done many upgrades.I focused initially on weight plate upgrades. We're now 4090kg, which allows me take all the toys I need for a proper holiday .Hi Mike, Thanks a lot, where did you find that info out of interest? I've been looking/asking all over.
Hi Neil, I'm home now. I presume from your Avatar you're in Norway. If I can advise on any specific task you may be thinking of undertaking give me a shout. My next task is a fixed solar panel on the roof, probably about 300w,I have already fitted an MPPT controller that feeds both batteries through the Schault Electroblok 119 unit, [ thanks Lenny HB and Autorouter] for advice. I also have fitted a B2B. Both units fitted side by side behind the Electroblok.Hi N
I'm away at the moment had a big drive yesterday,450miles, so a bit knackered. I'll pick up this thread when I'm back.Our van is manual. Euro6 but no add blue.
Mike.
