Discover leisure insurance (1 Viewer)
rogerrichards
11
Anglesey, North Wales
4 years
I'm probably the last person on the planet to have found out that Discover Leisure has gone into administration.
My MH is insured through them and I take it that they were merely the brokers and that I am still insured through the underwriters? Can anyone tell me if I'm wrong and should be looking to reinsure.
Regards
Roger
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Regards
Roger
Check with underwriters, you should be insured but any Discover own base warranties are null and void on used vans, the AA ones are Ok
Peter
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
You should be OK
You should be OK, as they only act as brokers. But you will need to contact the underwriters to have them confirmed that they did get your premimum from the broker.
Bob
sedge
Jul 7, 2009
5,511
13,155
Nr Jct 3 M6
Aug 09 to date 9,000 miles!
True you can check the MID but that relies on it being updated correctly by the insurer (they are sposed to have a max of 5 days from being notified of a change to do this) and it all depends, doesn't it, when Discover went to the wall, how long it takes insurers to sort it etc. Then in some cases, the client themselves needs to do the MID changes themselves - such as a multi-vehicle fleet where the changes are only notified to insuers every so often, sometimes annually - and for all we know, this may apply to schemes too ..... where the broker might have to do it......
However - it certainly used* to be the case that cover could not be withdrawn immediately in any case and insurers must write directly to policholders at their last known address pdq setting out the exact situation in respect of their particular policy.
* have not been involved in insurance for the last 3-4 years so don't know if anything has changed.
Ring the actual insurers, it's the only way to find out exactly in your own particular case.
Xabia
1,186
821
Since 1996
Depends on the terms of their agency with the insurers. Likelihood is that they are on 'risk transfer' which means that once they have accepted the premium on behalf of the insurers you are covered, the premium risk becomes one for the insurers to deal with as creditors.
Best thing is to ring the insurer on Monday to confirm the exact position.
