Diesel filler cap difficult to turn (1 Viewer)
Graham of Madrid
366
173
Mc Louis Glamys 40
Since 2019
Good evening !
I noticed after filling up that the filler cap was difficult to turn with the key. It's a 2018 model so I'm a bit surprised. Anyone else with the same experience/solution.
Thanks for any help !
Jul 29, 2013
9,076
18,646
Salisbury
Hymer B678DL A class
Do you mean the key is difficult to turn? Or the cap is difficult to turn with the key? As you should not turn the cap with key it has a grip on it to turn it.
Ours has always been a bit fiddly but I’ve got used to it now after two years.😊👍
Oct 29, 2016
4,511
53,050
Surrey
Carthago C Tourer
Ours 2018 played up at first, as it didnt always seal properly. Further investigation showed that it needed to be placed evenly flat on all sides before locking, otherwise it would only be gripping on one side allowing spillage when brimming the tank. (much more difficult than any car I have owned)
I applied some silicon spray to the rubber and the lock, no probs since, however I hope I can remember how to do it again as its been so long since we filled her up.
LES
Graham of Madrid
Graham of Madrid
366
173
Mc Louis Glamys 40
Since 2019
Thanks for your help.
Yes the cap is difficult to turn with the key, its a new problem that;s just surfaced. Maybe I'll try some silicone spray. Is there a brand I should be looking for as I'm shopping here in |Spain. Thanks
DJT
Jun 20, 2019
451
31,582
Cumbria
Now Sold
This one does the job 👍👍
tonka
10,847
21,562
Cannock, Staffs
A class Burstner 800
Since 2000
Going with most above. Avoid WD40 and go with silicon spray. Big can from Screwfix for just a few £'s.
I bought some graphite power for my key locks, just got to find it now.
Sep 9, 2019
876
1,926
Runcorn
Autotrail Apache 632
Since Sept 2019
Plus one for silicone spray. Also absolutely excellent for your electric windows, wind the window down, spray the rubber slots the glass slides up and down in, heypresto! nice slidey up and down windows again! I do this as a matter of course on all my vehicles, especially the ones without electrics, every six months or so. Make sure you shake the tin vigorously first though or all you'll spray on will be the propellant in the can!! :Grin:
Cheers!
Russ
11,939
9,125
It strips any grease off your workings and then after a few weeks it dries and needs spraying again ,plus it attacks rubber
53,693
150,975
Ok, every day is a learning day.... what’s up with using wd-40..?
Great for some jobs but you need to know its limitations. It attracts grit dust it drys out fairly quickly leaving the grit behind.
Also need tbe very weary on plastics a complete no, no, on nylon it makes it swell. Many a Motorhome door higes have been bu**ered by spraying nylon sleeved ones with WD40.
Oct 12, 2009
10,730
23,780
A Class N+B Arto 69GL
I agree with the comments about WD40. It is fine for freeing a nut temporarily but not for putting in a confined space where it is left, and dries sticky.
Graphite powder, or grease, is what professional locksmiths use.
Silicon spray if no graphite available, but graphite can be obtained from scraping a sharpened pencil 'lead', softer the better.
Geoff
Graham of Madrid
Graham of Madrid
366
173
Mc Louis Glamys 40
Since 2019
Thanks everyone, I have some silicone spray 3-in-1 and problem now solved. Also used it for other things too.
p-c
134
55
Berkshire
40 years
Please do not use the key to turn the cap. What will you do if the pressure of doing that snaps the key, part in your hand and part stuck in the lock!
Regards
p-c
Aug 18, 2014
23,863
134,528
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Regards
p-c
On my transit the key unlocks cap by turning 90º anti clockwise then you have to continue turning with the key to unlock & remove cap.There is/was no facility to turn cap using hand as it had no outside grip & is in a recess. Fortunately it wasn't a lot of cop when I bought it & a struggle to remove the first 2 times so when it refused to undo the 3rd time on way to the UK I smashed the lot off, fortunately with nothing going inside. The ridiculous amount they wanted for new cap meant I just left the temporary cap on & fitted a lock to the cover.
  • Thanks
Reactions: p-c
Graham of Madrid
Graham of Madrid
366
173
Mc Louis Glamys 40
Since 2019
Just to check that I'm right on this, there is nothing to get your hands on to turn the cap. The key must be turned. It's what I've always done. Its an X290. Can anyone confirm this please ?
  • Thanks
Reactions: p-c
p-c
134
55
Berkshire
40 years
Sorry, thanks for correcting me. Turning the key to remove the cap is not something I have come across.
Regards
p-c
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
Regards
p-c
e z mistake.
I was reading that the key was being turned to get the fuel cap off & was surprised.
Seems legit for this fuel filler type tho :)
(y)
  • Thanks
Reactions: p-c
Graham of Madrid
Graham of Madrid
366
173
Mc Louis Glamys 40
Since 2019
Thanks to you both, it turns much easier now. One less problem
