most panel vans are galvanised nor so rust not such a problemAny long term leak not spotted would or could result in rust, I suppose, against the danger of damp in a plastic van's framework rotting the basic structure.
Agree as above.You can get damp in a pvc just like any other motorhome due to all the cut outs for roof lights and windows or even condensation if the insulation is not good enough.
Yep I believe that is correct but if in doubt contact Hymer via their website and ask the question.Contacted my supplying dealer to arrange damp test on my Hymer PVC as it's due next month.
Was told damp testing on PVC Hymer's was not required, is this correct?
In theory!most panel vans are galvanised nor so rust not such a problem
I have previously considered filling in the troughs crossed by installed units, all I could think of was lon strips of poly prop or similar to fill them in, stuck down with adhesive. Firstly I don't think I'm up to the job, anything I try to stick down doesn't, and if the adhesive is not completely even there would be further chances of water creeping in and not being dried by exposure to air. So I gave up the idea. Have you done it?The main threat comes from the troughs in the ribbed roof, they have to be filled in with something to form a flat surface for the roof lights to sit on. They also hold the water against whatever has been used and thats where the leaks start from.
I used some strips of plastic with plenty of Sika mastic, I still had a leak which I noticed after 5 years from first installing the roof light and I had to replace a good area of the ceiling plywood. Now I have even more Sika in place, does not look very tidy but only I can see it and it does not leak.I have previously considered filling in the troughs crossed by installed units, all I could think of was lon strips of poly prop or similar to fill them in, stuck down with adhesive. Firstly I don't think I'm up to the job, anything I try to stick down doesn't, and if the adhesive is not completely even there would be further chances of water creeping in and not being dried by exposure to air. So I gave up the idea. Have you done it?
