Conformation gearbox odd behaviour
Nosmo King
2019 Fiat Ducato 2.3l 150bhp comformatic , 4000 miles
On our way to Scotland rwe had a strange issue with the camper.
Did about 100 miles then stopped for a pee at the motorway services. 20 minutes or so. Started the engine and made our way back to the motorway.
Gearbox seemed to be hanging on to the gears a bit longer but we were moving slowly through the car park.
Got on the slip road and gave it a bit of throttle. Still hanging on to the gears, 1st 2nd 3rd. Then it dropped in to neutral. Tried to switch to manual but it wouldn’t.
Pulled over on the slip road. Still in neutral. No gear selection worked.
Switched engine off. Removed key. Replaced and restarted.
Everything back to normal!
Anyone had this or something similar before?
You didn't have this button pressed did you?
319242
Mine is a 2017 but the engine and gearbox are the same as the OP. There was one isolated incident at 650 miles from new when in Auto mode the upchanges became very slow, and then for no reason it got stuck in 3rd after a roundabout. I finished the rest of the journey home using manual gear change mode and going quite slowly. Next day it was back to normal in Auto mode. The Fiat workshop failed to find any error codes. It was a one-off.
I haven't had mine long enough to say much, have only driven it the 70km home so far, but it did seem to behave a bit oddly after one roundabout where it seemed very reluctant to change up.
Hada 2014 did 20,000 miles in it, now have a 2017 done 18,000 not had any problems like that. Fingers crossed it's a one off. Had the engine throw a couple of wobblies but just the once.
Thats normal.
It shouldn't change into neutral on its own while driving. That's a fault so get it checked while in warranty. :)
Hydraulic pressure in the mechanism low? or maybe abit of frothing in the system, check the level for the servo system, in the little header tank.
Not on a Comformatic it's a robotised manual box.
Ours is 2016,11000 miles. It occasionally gets stuck in a particular gear and refuses to change unless I manually do so. It’s never gone into neutral on its own though. To be honest it’s not the best behaved auto gearbox but I wouldn’t be without it. In traffic it’s a God send.
What does the manual servo moving, I thought the one I examiined had a small resevoir with hydraulic fluid.. They are not mechaniclally moved the gearbox might but not the servos.?????????????????? OR, is it really as I imagined a gnome under there with a pedal and gearlever?
I had a Smart. some years ago, which would do similar. Suggestions from the "Smart" community mostly suggested BAD Earthing (not unlikely, as most canbus type control systems use such tiny currents). Eventualy the gearbox did fail quite spectacularly, wrecking both it and the engine, when under tow. That was down to a FALSE Neutral indication. SWMBO`s new Nissan has also done a similar thing, you stop the vehicle switch off and re-start. Doesn't show up as a "fault" on diagnostics either!. Just puts the "fault" light up on the dash!, which clears on re-start?.
The small reservoir could be for the clutch , I would have imagined the gear servos would be electro magnetic
