CamperJack
I planned on getting a 12V compressor (specifically a Dometic / Weaco crx50) but now it is time to buy one I am loathed to spend the extortionate amount of money they cost and for something so pathetically tiny compared to a 240V undercounter fridge. I don't understand why 12V should be so expensive, except for the fact that if a manufacture can get away with charging such a lot they will. I don't want to spend £600 on a fridge!
With that in mind I have been doing some research online. I am considering using a 240v fridge. Now, before everyone screams no at me, I'll show you my research and calculations. Then you can scream no at me.
POWER CONSUMPTION
Russell Hobbs RHUCLF2W 240V (£200)
Consumption = 110 kwh/year
110 X 1,000 = 110,000 w/year
110,000 w / ( hours in a year = 24 hours X 365 days) = 12.55 w/hour
12.55w / 12v = 1.04 amps/hour
1.04 X 24 = 24.96 amps per day.
Factoring in inefficiency of the invertor - 10% for the one I am looking at (Novopal 1000W pure sine wave) = 24.96 amps X 1.1 = 27.46 amps per day.
We also have to consider the invertor on standby, (not running the fridge compressor but still switched on and drawing power). For the Novopal that's 0.6 amps per hour so: 0.6a X 24 hours = 14.4 amps.
Total power: 14.4 + 27.46 = 41.86 amps per day.
Dometic crx50 (£600)
The amps rating given for the Dometic is 1.7 amps / hour.
1.7 X 24 = 40.8 amps per day.
So that's a difference of 1.06 amps a day in power consumption between the Russell Hobbs 240V and the Dometic 12V.
So, the difference isn't as colossal as I thought it would be!
However...
The figure of 1.7 amps an hour for the Dometic is at the higher end of the 1.2 - 1.7 amps rating. If we take it to be 1.2 amps the consumption figure is 28.8 amps with a difference of 12 amps in favour of the 12V. We can safely assume is is somewhere between the two depending on environmental temperature and how much it's open etc, perhaps 30-35 amps would be realistic, so a difference of 10.8-5.8 amps?
Also we have not accounted for the impact of extremes of temperature in a van on the running of a 240V fridge, and I would hope to assume those at Dometic have. But who knows the truth. Rather like my car is quoted at doing 61 MPG. In reality that is only in dream land! I
That being said I found a guy on YouTube from Sterling Power testing 12v compressor and 240V fridges via an invertor and his results were similar to my calculations. He measured the amps to run the 12V fridges and a 240V through an invertor was not using a huge amount more, and his 240V included a freezer, which my 240V didn't. In addition he showed that once at temperature the fridges used similar amps to maintain the set temperature.
With this in mind, and a difference in consumption likely to be somewhere between 1 amp and 12 amps, I am very tempted to at least try a 240V fridge. It would be worth saving £400! Even with the cost of the invertor (£150) I'd be saving £250 and I'd have an invertor for other 240V items like my stick blender etc.
To generate the 42 amps required I have 340W of solar and a 30 amp B2B. I also have 220ah of lead acid batteries.
As always though I hope you offer suggestions and opinions! Am I wrongly talking myself out of a 12V compressor?
POWER CONSUMPTION
However...
