Coleman 6 in 1 table
UK
Burstner
Few years now
I am thinking of removing the table on my Adria Twin to give us a bit more room in the living area and purchasing the Coleman 6 in 1 table which should fit in its place in its single configuration. It would also give us a few options for outside living as well. Anyone used this table and if so what are your thoughts on it?
Thanks H
I had a look at this YouTube video on the tables features and I'm wondering if it is a bit to versatile in that would you just end up using it 90% of the time in the one configuration that suits you best, and I would find it a bit long winded putting all the bits together to make up the large double high table and then fiddling about on your hands and knees adjusting the feet to have the two sections the same height on uneven grass which tends to be the case, mind you it would be good entertainment and having a giggle for others watching you put it all together and dismantling it.
It ain't cheap is it.
It is the only table I could see, which would fit . Plus it offers another the other half for use outside.
I think it is a great idea and very versatile. I have a similar table but it folds in half rather than having 2 separate tops. Love the way the legs store inside.
Looks like you didn't really want opinions as you have already made you mind up ?
Not yet. It looks good on the video, just wanted to see if anyone had real life experience. I would also look at other options if I could find something up to 500mm wide and no more that 800mm long.
Far too much hassle, keep the fixed table you will soon get used to it.
Need to update your profile it says "Don't own one yet"
I did look at changing it, but could work out how. I couldnt see in my profile where I can change the the MH bit
The trouble with these light weight alu tables (we all have similar) is as mentioned a lot of faff using on uneven ground, or in stiff summer breezes without some weight on top they blow over.
Also just ever so slightly nudge any part with your leg/foot whilst in use and you will have big spillages to mop up everywhere, or am I just a clumsy bugger?
If you do use one or similar with friends & family, best advice is always have the kitchen roll ready in the middle, at least they can wipe up their own mess.(y):giggle:
IMHO, Stick with your supplied interior table for a while longer, its been designed to please the many, but may disappoint the few.
LES
Click on your name in the blue band at the top of the screen, then click on "Account details"
