Hi all, hope someone can help with respect to a cooling fan fault on my van. Have had the van for two years. Initially after a service I noticed the coolant was on minimum mark so filled it up mid way between min and max. Had a second service done this year and went on a trip. Later discovered coolant on min again So filled it up mid way. Checked for leaks but couldn’t find any. No oil in water and no water in oil. temperature gauge at normal, no fans running when on a run and no warnings, but slight whiteish smoke on start up and sweet smell which soon dissipated. Suspected head gasket. Sent into main dealer for pressure and combustion tests. Result was No HG fault but water leak at pump. Pump replaced. Also told that high speed fan worked ok but low speed fan faulty. £700 please was the quote. Drove home from dealer and checked coolant, it was on the min mark! Well that’s the history. Can anyone tell me what Controls the cooling fan. Do they both run in high and low speed. Does the AC activate the fans in low speed and does the outside ambient temperature have any interaction with the control of the fans. I intend to check the operation of the control circuit myself before parting with £700 but need to know full operation of the fans first.
