ShiftZZ
Worth the effort ?
Pro con?
Pro con?
I suppose you could use a usb plug in drive for storage ?Also, they have tiny storage.
Evil Google? Any worse than incompetent Microsoft, or dictatorial Apple?
I've just downloaded an "Office" equivalent.Thanks Motorhome-dude , if I went for the windows laptop, would I be able to load my 2003 MS office or should I get an up to date version ?
Or maybe something off the internet I can download to use instead ?
I put office 2003 onto my window 10 pc and it works OK but sometimes crashes when closing. I use libra office now, it's a free download and does almost everything MS office does, has the option to save in many formats including MS office.Thanks Motorhome-dude , if I went for the windows laptop, would I be able to load my 2003 MS office or should I get an up to date version ?
It really depends on what you use a laptop for. If it's just emails, internet browsing and online video watching then a Chromebook is ideal as it's fast, reliable and very unlikely to get any of the viruses that Windows stuff is prone to. If you need to work on it however, or use a lot of word or Excel, or anything more heavy duty like Adobe Software then the negatives of the Chromebook outweigh the positives and I would recommend a solid state drive Windows based laptop.
You might want to consider replacing the operating system on your Windows laptop with Linux? A number of Funsters have done this very successfully.Owing to the wet weather yesterday, I decided to take the opportunity to visit Currys to check out replacing my ageing windows laptop with maybe a Chromebook.
I have no idea how I would do that, is there a tutorial on youtube maybe ?You might want to consider replacing the operating system on your Windows laptop with Linux?
There's a huge number of "how tos" and videos on the web.I have no idea how I would do that, is there a tutorial on youtube maybe ?
Just to re-iterate. Download Mint MATE (or Xfce if your laptop is 10 years old). Write the installer to a memory stick. You can then boot from the memory stick and run it entirely from there without touching Windows. It's a good test for compatibility, but it'll be slooooow. Check the screen resolution, sound, wifi and touchpad all work.There's a huge number of "how tos" and videos on the web.
Suggest you Google "how to install Linux Mint 19.1" and have a look at some of the results.
As a starter here's the official Linux Mint website https://linuxmint.com/
Check the spec of your laptop to determine it meets minimum requirements \ version you should download. What model of laptop do you have and what version of Windows is it currently running?
One huge positive is you can download the system to a USB stick (suggest a min of 4-8Gb) and run it from there to test prior to installing. This leaves your existing Windows system intact. Once you've tested (note it doesn't run as fast as when it's installed) you can just click Install (or something like that). This will give you options to overwrite Windows system or install alongside it.
If you go down the Linux route there are a number of Funsters who will be in a position to help.
Any questions ask away.
May I ask what it was called and where from please ?I've just downloaded an "Office" equivalent.
This appears to do 99% of Microsoft Office, in fact I haven't found anything it can't do yet.
Phil
