gerry mcg
it might be worth while checking your sliding door soft close mechanism - i’ve been troubled with the central locking not working properly as a result of the sliding door not making proper contact with the door close contact and giving me a "rear door open error" on the dash - when i had a good look at it, i think the problem has been a result of the auto-close catch becoming unscrewed - and kind of falling apart.
the soft close mechanism comprises 2 metal plates - held together with 2 hex bolt, each with a hollow metal roller - the outermost of the bolts had become completely loose/ disengaged from the rear-most plate - causing the rear plate to drop down from the horizontal position to a vertical orientationallowing the soft close mechanism to flex - as it is only held in shape by one bolt, not 2.
i removed the both bolts - reapplied loctite to the hex bolt threads and screwed them back into the plates together tightly and hey presto - no door more problems closing the rear door and central locking.
the photo is taken is looking at the rear most edge of the sliding door frame on the chassis at the soft door close catch - I had to remove the door stop that prevents the door from completely slide rearmost when open to get proper access (3 screws on the lower door frame runner)
the left most (outer bolt was completely disengaged from the far (rearmost) plate of the soft close mechanism and the rearmost plate was hanging vertically downward.
the electrical door close switch is the black contacts at the bottom of the picture
